FS in Los Angeles: pair of JBL Control 328C/T 8" coaxial compression driver
  • FS in Los Angeles: pair of JBL Control 328C/T 8" coaxial compression driver
    Hello,
    Was going to base the L/C/R of my system on these, but decided to go with slightly smaller Tannoys, which have been fine.
    These are really well made, and in good condition. Looking for $183 for the pair, firm. No shipping as they would be awkward to ship due to bulk (compression driver off the back, massive crossover board, etc.) One port fell off of each speaker, but that didn't concern me as I was going to use the speaker/crossover, not the mounting plate with the ports.
    Best,
    Tal
    Factory JBL page.
    Frequency Response (-10dB) 45 Hz – 18 kHz
    Power Rating See transformer taps
    Transformer Taps 68W, 34W, 17W, (& 8.5W @ 70V)
    Frequency Response (±3 dB) 60Hz – 16 kHz
    Coverage Angle 120° conical, constant directivity
    Impedance 8 ohms
    Directivity Factor (Q) 7.0 (Avg 1k - 16kHz)
    Directivity Index (DI) 8.5dB (Avg 1k - 16kHz)
    Sensitivity 93 dB (1 kHz - 16 kHz)
    Maximum SPL (1m) 118 dB (top 70V/100V tap)
    Crossover Network 1.9 kHz, 3rd order (18 dB/oct) high-pass plus conjugate
    Dimensions (H x W x D) 305 mm (12.0 in.) diameter round baffle x depth from back of baffle of 218 mm (8.6 in)
    Input Connectors Screw locking barrier strip for bare wire
    Drivers LF Driver: 200 mm (8 in)
    HF Driver: compression driver, 25 mm (1 inch) coil
    Click image for larger version  Name:	control_328c_front_z_original.jpg Views:	0 Size:	132.9 KB ID:	1461785
    Click image for larger version  Name:	control_328c_back02_z_original.jpg Views:	0 Size:	165.1 KB ID:	1461786
    Hi there, I'm very intrigued--mostly looking for some Tannoys myself. Which ones did you end up going with, and can you describe the sound of these?
