FS: Five W3-1053SC 3" Full Range Drivers, 5.1 project set
  • FS: Five W3-1053SC 3" Full Range Drivers, 5.1 project set
    Hey guys,
    Over the past several months, I had a dream to build my own 5.1 sound system for my bedroom. I bought nearly all the parts, except for the cabinets, which I thought I could build myself. I did use 2 of the five drivers for testing to see how they sounded in prototype 4-layer-cardboard cabinets (ported). They sounded fantastic (I tried using them both bare and also with a cloth dome tweeter - great sound either way)! But alas, life has knocked, and I just do not have the time or the motivation to finish this project right now. I'm in the middle of de-cluttering our place, and instead of having this stuff hang around, I've decided to let it go.
    A poster on TechTalk forums by the name of Brian Powers has two projects based on these drivers (He no longer posts here, but his projects can be found - search for them). One is a single driver speaker with notch filter and the other is a dual driver speaker with notch filter.
    Below are all the pics - Remember there are 5 of everything, except for the tweeters and the caps/coils (those were just for experimenting with the sound). The two full ranges I did use were in use for about 4 or 5 months, so they have plenty of break-in. No damage on any drivers, and I did not solder anything. Included is an unused 3" hole cutter for your drill or drill press, and ~10 ft. Dayton 18 awg OFHC wiring, 5 terminals, 2 JAMO softdome tweets, 2 Jantzen coils, 2 Jantzen caps, and five 1" port tubes.
    If you are interested, please PM me with an offer. I'm in the San Francisco Bay Area, but I will ship for FREE to anywhere in the lower 48 states, so please consider that in your offer. I don't mind giving someone a very good deal, but no low ball offers, please. These Tang Band drivers are currently going for about $15 a piece - definitely a good price for this sound. Paypal works for me.
    Specs below...
    http://www.parts-express.com/pe/show...number=264-880
    Tang Band W3-1053SC 3" Full Range Driver
    Made by Tang Band but available exclusively from Parts Express! The W3-1053SC has an attractive pincushion style frame, edge-damped poly cone, flat spider, and rubber surround. Underhung 7/8" voice coil provides linear travel and wide range. Extremely smooth, extended frequency response. Neodymium magnet with black plastic heat sink fins.
    Specifications: • Power handling: 15 watts RMS/30 watts max • VCdia: 7/8" • Le: 0.44 mH • Impedance: 8 ohms • Re: 5.98 ohms • Frequency range: 100-18,000 Hz • Fs: 100 Hz • SPL: 85 dB 1W/1m • Vas: 0.04 cu. ft. • Qms: 4.77 • Qes: 0.72 • Qts: 0.62 • Xmax: 1.5 mm • Dimensions: Overall diameter: 3-3/16"; 3-13/16" diagonally, Cutout diameter: 3", Depth: 2".
    JAMO 20141 1" Shielded Soft Dome Tweeter
    Compact tweeter features a textile dome, plastic faceplate, and ferrofluid cooling. The hole-less faceplate design lends itself to press-fit, glued-in, or clamped installation. Offers interesting possibilities as a waveguide driver. The motor and diaphragm share the same snap-in mounting system as other Philips/Norelco dome tweeters. Magnetically shielded. Made by Philips for JAMO. Manufacturer buyout, limited quantities. Specifications: *Power handling: 40 watts RMS/80 watts max VCdia: 1" *Impedance: 8 ohms *Re: 5.0 ohms *Frequency response: 1,600-18,000 Hz *Fs: 1,670 Hz *SPL: 87 dB 1W/1m *Dimensions: A: 3-3/8", B: 2-7/8", C: 1-3/8".
    http://www.parts-express.com/pe/show...number=299-944
    Re: FS: Five W3-1053SC 3" Full Range Drivers, 5.1 project set
    Originally posted by Ken B. View Post
    Hey guys,
    PM sent.
    When the only tool you have is a hammer, all problems start to look like nails.
    Some people collect stamps, Imelda Marcos collected shoes. I collect speakers.
      You have another PM...
      Jason
      "In my opinion, there are more tactful ways to state your opinion."
        Hi Ken:
        Sent you a PayPal payment and a PM.
          thekorvers,
          Did you buy it all?
          Jason
            Originally posted by RINNAV View Post
            thekorvers,
            Did you buy it all?
            Yes, he offered it as a 5.1 project set. I'll probably end up building a small 5.1 single driver Bose Beater set with a simple contouring filter and end up gifting it.
              Received these a few days ago, well wrapped and in excellent condition.
              Thanks Ken. It was a pleasure doing business with you.
