Midwest Audio Fest
See more
See less
Quick fix for "20 dB low" problem in Windows 8
This is a sticky topic.
  • Quick fix for "20 dB low" problem in Windows 8
    Do the following:
    • Make sure OmniMic isn't running.
    • Find the Omnimic.exe file (probably in C:\Program Files\OmniMic or C:\Program Files(x86)\OmniMic) with the file browser, and right-click on its file name.*
    • Then choose "Properties" from the menu that appears
    • Then click on the tab labelled "Compatibility", in the "Compatibility mode" box select "Windows XP (Service Pack 3) and put a check in the checkbox labelled "Run this program in compatibility mode for:"
    * (You can instead do this process for any icon or menu shortcut that you use to start OmniMic, but then it would only apply the fix when you run OM that way).
    Free & Free-form simulator/designer for Passive Crossovers
    SynergyCalc 5: design spreadsheet for Wooden horns and DIY Synergy Waveguides
    Super easy and cheap to make high performance sound diffusers
    Bill, I'm assuming this is to fix the SPL meter not reading correctlly?... Hopefully yes !! Here's my situation...
    I originally had a Windows 7 PC that I measured with, but it was shared by the whole family which is kind of a nuisance. So I got a Windows 8 PC that I planned on dedicating to just my speaker software, but I couldn't get the OmniMic's SPL meter to read above about 69 (ish, IIRC) db. So I stopped using that and went back to my old PC for measurements.
    Well, one of my kids upgraded my old PC from Windows 7 to Windows 10, and now I have the same issue with that one as I had with the Windows 8 PC. Will this fix the Windows 10 too? Seems to do exactly the same thing that my Windows 8 PC did, the SPL meter won't read above about 69 or so db.
    "The ability of any system to produce exceptional sound will be limited mainly by the capability of the speakers" Jim Salk
    "Audio is surely a journey full of revelations as you go" JasonP
      My omnimic does exactly the same thing on Win10. While taking FRD measurements I can not get it to read any higher than 68-69db. I assumed it to be a calibration problem with my microphone. So maybe it isnt?
      Either way I won a new Omni at MWAF, but I am forwarding my old mic to anither competitor who needed one, this info may be very useful for both of us.
        It isn't the mic, it's Windows. The "quick fix" he describes also works with Windows 10. To get it to work though, I couldn't do it thru the "OmniMic.exe file", I had to right click on the OmniMic icon, select properties, then follow his^ instructions from there.
          I was able to get mine working properly (my NEW OmniV2 that is).
          Bummed I dealt with the problem for so long, though.
            The fix mentioned above shouldn't be needed with the most recent version update of the Omnimic software --it senses when the OS is windows 8 or later and applies a similar adjustment internally.
            The issue with Win8 and forward is that Microsoft helpfully decided to change the 'taper' and interpretation of the recording level settings for its microphone inputs, which of course hosed any programs that were counting on the previous handling of the level settings.
