power is being delivered to the driver?
  • power is being delivered to the driver?
    I just purchased OmniMic V2.
    . put the yellow CD into my CD player.
    . chose track 9
    . placed the mic at 1 meter on axis
    I have no way to know how much power is being delivered to the driver.
    Website
    Re: power is being delivered to the driver?
    You will want to use track 18 or 19 (50hz tone) and then measure your voltage output from the amplifier (looking for 2.83 volts) using a multimeter on the ac volt setting. This will give you your 1 watt output so you can measure the efficiency of your speaker. Remember to take the measurement with the speaker unhooked.
    PS - read through the help files - there is so much info in there to help you learn how to use the OmniMic!
    See my projects on Instagram and Facebook
      Thanks, can you suggest one that's good but inexpensive?
      Website
        Not sure how else to do it - that's the way I was told how to do it.
          I bought one of these for using at home - it should do the trick and not expensive at all
          http://www.canadiantire.ca/en/pdp/ma...l#.VhrUR_lVhBc
            That looks handy, thanks.
            Website
