Microphone to mixer/amp hookup HELP!
  • Microphone to mixer/amp hookup HELP!
    I'm trying to hookup 2 ceiling mics, each with 3 XLR connections. They are being hooked up to a Bogen GS60D mixer/amp that has only 4 XLR connections. How is this done? Do I wire the microphone as 1 XLR instead of 3?
    Provide a link to the mics, I can't see why a mic would have three connections.
    www.billfitzmaurice.com
    www.billfitzmaurice.info/forum
      Here is a link to the microphone.
      Http://clearone.com/products_ceiling_microphone_array
      I'm kind of thinking there is no need to have the cord break out into 3 XLR connections.
        It appears that you purchased ceiling microphone arrays, which contain 3 microphone elements. They are intended to be used with their own proprietary mixers that have DSP algorithms to enhance the use of their microphone arrays. You can most likely hook up just one of the XLR connectors that corresponds to the center microphone. You will also need to turn on the phantom power for each channel.
          Unfortunately I didn't pick them, but that makes sense. Thanks for your help.
            If you have plans of selling them. Please pm me. Sorry for the OT.
              tanda4, I hope you could share some insight about the product once you tested it.
                from skimming this:
                http://clearone.com/uploads/resource...nst_Manual.pdf
                I'm left with the impression that this product was designed to work with their mixers.
                  We use Audix M3's (they look to be similar) to ensure coverage for UC spaces. Typically, we'll use a BiAmp DSP to handle the processing/AEC. Based on what I see here, I think you could use these with a third party DSP if you had to.
                    Yes, pretty common in a conference room, used for audio conferencing and/or in conjunction with a video conferencing system.  A DSP like a BiAmp with AEC, as mentioned, would handle it just fine.  No need for anything proprietary, even though ClearOne would like you to believe there is.  On a side note, while ClearOne was once at the forefront of audio conferencing systems, they've been left behind in the last decade, at least.  Anyway, treat each of those units as 3 separate microphones, each needing a dedicated input channel of they're own.  So, 3 inputs for 1, 6 for 2...
                    Have to ask, what is the intended use?
                      You need to splice the red wire to the white one and yellow to the black then attach a power supply directly from the battery. Once this is complete you should be good to go.
                      • #12
                        It creates the impression that you obtained roof mouthpiece clusters, which contain 3 receiver components. They are expected to be utilized with their own restrictive blenders that have DSP calculations to upgrade the utilization of their mouthpiece clusters. You can probably attach only one of the XLR connectors that compares to the inside amplifier. You will likewise need to turn on the apparition control for each channel Plex Lucky Patcher Kodi .
                        • #13
                          Originally posted by rossi123 View Post
                          It creates the impression that you obtained roof mouthpiece clusters, which contain 3 receiver components. They are expected to be utilized with their own restrictive blenders that have DSP calculations to upgrade the utilization of their mouthpiece clusters. You can probably attach only one of the XLR connectors that compares to the inside amplifier. You will likewise need to turn on the apparition control for each channel.
