1 of 2 < >
Midwest Audio Fest
It’s that time audio enthusiasts!
Registration for the 2019 Speaker Design Competition is now open! Visit midwestaudiofest.com for details and to list your speaker project.
We are excited to see all returning participants, and look forward to meeting some new designers this year, as well!
Be sure your plans include a visit to the Parts Express Tent Sale for the lowest prices of the year, and the Audio Swap Meet where you can buy and trade with other audio fans.
We hope to see you this summer!
Vivian and Jill
2 of 2 < >
Midwest Audio Fest
See more
See less
dose anyone have a good design for a 12in pa mains
  • dose anyone have a good design for a 12in pa mains
    I was looking to build some 12in mains for studio and pa use and was wondering if anyone has a good design. I already have a pair of Eminence Kappa Pro-12A and a pair of B-52 comp-4-mx or PRV D230Ti-Nd-B. Could any of these work good together?
    Those should work just fine, I built a a set with Delta-lite 2512 and D210ti drivers some time ago. How are your wood working skills? If these will be used with subs all the time a small box tuned to 60-70hz will do it.
    Paul O
      my wood working skills are good. right now they would be used with one 18in sub or two 15in subs. also was wondering if two selenium 15sws800 would work in two 6cubic foot boxs?
        They would but won't take much power. That driver doesn't need a large box.. 3 cu/ft per driver internal volume is plenty so you could have a double 15 in 6 cu/ft or have two really compact subs.
        Paul O
          Right now I have two 5.5 cubic foot boxs for a 15in sub. Would these work good in these or would it be to big?
            Too big, they would have to be limited to about 250w. Is the baffle big enough to fit both drivers in one box? You will likely have to cut the baffle out and install a new one but that would give you a potent box.
            Paul O
              Could a 4.5 cubic foot work?
                5 cu.ft. looks a bit too big.
                OTOH, 2.5 cu.ft. per driver, if you use two in a box, might be on the small side. The PE page on the driver suggests a 2.02 box tuned to 49 Hz, but that's a "maximally flat" alignment, and probably not the best for this driver.
                Selenium's documentation suggests that the driver was tested in a "100-liter volume with 3 ducts ø 4” by 4.72” length". 100 L is about 3.5 cu.ft.
                Brian Steele
                www.diysubwoofers.org
                  ... a pair of B-52 comp-4-mx or PRV D230Ti-Nd-B....
                  The PRV doesn't have a low enough response ( 2,000) to integrate with a 12 without large compromises in performance.
                  The B52 would be better, but a common problem with this type of 2 way configuration is a large woofer falling response and directionality at the high end.
                  If you are going passive count on applying a lot of attenuation on the compression driver.
                    do any of you guy know of the ev sh-15-2 i have a pair of those would the horn drivers from those work good?
