Notch filter power handling question.
  • Notch filter power handling question.
    When a speaker rated at 300 watts uses a notch filter like this:
    3.3 ohm (10watt), 125uf, 52ml (120 watt) are those values (resistor, coil) good enough for the 300 watt rating? (I'm thinking that the notch filter does not draw much power)
    Are they good enough for a 600 watt rating?
    Trying to get my PA midbass horn good enough to use when EQ is not possible.
    Thanks in advance.
    Two very good sociological markers.
    The state of our public wash rooms.
    How we treat each other behind the safety of a monitor and key board.
    Re: Notch filter power handling question.
    Cap ratings are based on voltage, while what matters most for the coils is DCR; it should be no more than 5% of the driver impedance, and usually when you get the gauge large enough to realize that it will have adequate power handling. The resistor is what's hardest to call, you have to calculate how much power it will drop.
    EQ is not optional equipment.
    www.billfitzmaurice.com
