Cabinet Design Help
  • Cabinet Design Help
    Hi all! New guy on the block needing a little help. I usually hang at the Jazz Guitar Forum and TDPRI. I'm currently using a sealed cabinet for jazz guitar housing a 10" Seismic Audio speaker (8 ohm) - it's powered by a G&K MB200 class D bass head that delivers 140 watts into the 8 ohm load. The combination works pretty well but I'm thinking about building a ported cabinet for better bass response and opening up the sound a little. I'm thinking along the lines of the Raezer's Edge type design. I have a couple 8 ohm JBL MI 10's sitting around and was thinking of using them in a pair of cabinets @ 8 ohms each, with the result that, if needed, using them both in parallel would let my amp deliver it's full 200 watts into 4 ohms. My problem is coming up with the proper design parameters for cabinets using these speakers - the JBL site is not much help, although I do have the TS design data for the speakers, I need some software to plug it into - preferably something that I can understand. Ultimate result is a pair of small, light guitar cabs with good frequency response. I generally use pine for my cabinets (with plywood baffle) as it's readily available, lightweight, affordable and, in the small sizes, stiff enough for the job. I need to come up with the cabinet volume and port area before I can start building. Am I also correct in assuming that, in a cabinet such as this, a port tube would not be required - that just the opening, sized properly is sufficient?
    Thanks for your help!!
    Re: Cabinet Design Help
    Download a copy of WinISD Pro(it's free), enter the TS specs for your driver and then run a SIM with it. http://www.linearteam.dk/?pageid=winisdpro
    Paul O
      Guitar drivers can be literally tossed into any cab large enough to house them and that's about it. Some prefer the tone of a sealed cab, some prefer open back, but the response modeling you do with every other speaker type just isn't required. Guitar cabs are very seldom tuned and ported.
      www.billfitzmaurice.com
        If you post the T\S figures, I could run it through Bass Box Pro and get you the cabinet specs you desire, but is the deepest possible bass on a jazz guitar really what you want?
