Microfarads- Nano Speaker using PS95 and W5-2053
  • Microfarads- Nano Speaker using PS95 and W5-2053
    As I'm packing these things to go to InDIYana I thought it's time to do a gallery post on what I'm calling the Microfarads!
    Project Description:
    This is the most challenging smallest speaker I've built to date. Due to the strict enclosure volume restrictions, this is also the most precisely built speaker I've made with each cut toleranced to less than 1/32".
    Total internal volume (not air space) is 3 liters including the PS95 sub-enclosure, I was pretty frustrated about some of the nonsensical restrictions on this project initially but ultimately grew to appreciate Ben's sense of neurotic restricted creativity =) The subwoofer is the Tang Band W5-2053 with 2 Peerless 5.25" per enclosure. Crossover frequency is about 300hz
    Design Goals:
    1 - Build a full range speaker capable of solid bass with smooth response to 20kHz
    2 - Total internal volume of 3 liters including mid enclosure
    3 - Unique striking look
    4 - Ensure every possible square inch is covered by a sound radiating diaphragm =)
    Driver Selection:
    I tried a few different drivers but always knew I'd end up with the W5-2053, this thing is a monster and the bass it puts out from only 3l is astounding.
    Was an interesting driver to work with as it's response falls off a literal cliff at around 1kHz, so I used that to my advantage in the XO. I had a pair of PS95's I'd been wanting to try out and was shocked by how good they sounded, so after trying some different drivers I settled on those. They were also welcome with the limited space I had to work with.
    Enclosure design:
    This was purely determined by 2 factors...driver and PR mounting dimensions and the strict internal volume requirement.
    As you can see it's all a tight fit. Precise calculations were made initially using some triangle area calculators to ensure internal volume was at or less than 3l.
    Passive Radiators ended up with no weight which resulted in a 56hz tuning frequency, more boosted than I wanted but adding any weight maxed out the excursion that much sooner. I was able to add 15 grams to bring it down to 50 but the passives were straining much sooner, as is the W5 easily over powers 2 5" PR's, really 3 or 4 of these would better keep up with 1 W5.
    Another passive radiator issue I dealt with early on was "enclosure walk", using dual opposed passive radiators solves most of that. Also Sorbothane feet in 30 durometer further eliminated any chance of movement.
    Enclosure Construction:
    Construction is solid mahogany, angled joints are mitered, all glue construction.
    I made this CAD (Cardboard Accurate Dimension) to help with the initial concept, I also used it to check test cuts to ensure things were aligning and helping with angle calculations:
    Plywood test cut that was perfect, this locked in all my angles on the table saw:
    Tape held it all together:
    In Mahogany:
    I made the cut out of one board to match the grain:
    Attaching front baffle:
    My cut list:
    Test fit:
    Clamping and gluing the baffle:
    Before I attached the sides I wanted to finalize the mid enclosure, since the PS95 needed no airspace to play to 300hz, I molded a tight fitting fiberglass enclosure. I started by mounting the driver into a board just like I would in the final enclosure, then I built a makeshift mold using layers of alum foil and masking tape:
    Fiberglass matte:
    Polyester resin:
    Wala, about 5 layers:
    Removed from the mold:
    Trimmed up and painted:
    Built into the mold was a 3/16" Sorbothane disc which creates a CLD treatment to the back of the enclosure, as the driver is screwed down it loads up on this viscoelastic dampening medium and greatly acoustically dampens the mid enclosure. I tested this and it works well:
    Mounted, it is attached with silicone adhesive and some screws for good measure:
    Javad Shadzi
    Bay Area, CA
    Time for some sides:
    All panels glued and flush, ready for some roundovers:
    I didn't have enough room for a full 1" round over like I wanted to do, but fortunately the W5 wouldn't benefit from it, so I developed a way to do a tapered round over using a wedge for the router bearing to ride on:
    This created a precise contour that cleared all driver frames. And all round overs and treatments done:
    And a coat of Danish Oil, BOOM! There's the grain!
    And after soaking in:
    Crossover Design:
    I tried many designs including various frequencies and electrical slopes before finalizing on what I have here. I ended up with 18db on the mid and 12 on the sub. Since I was crossing over at 300hz I used an Lpad to not only balance out the more efficient PS95 but also as a baffle step function.
    The PS95 also displays break up bad above 15k but it starts around 9k, I implemented a 12db low pass sound 10kHZ which rolled off the top end nicely until it was voiced the way I wanted. Not sibilant but with air and space. Indicators are 18ga, all capacitors are electrolytic except for poly in the PS95 top end roll off and the 1uf listed in the schematic.
    I tuned this until it had a flat response but like that the highs just fell flat, despite loving the FR plot it just didn't sound rift, so what sounded best is what's below (near field at about 12" centered on the mid.
    Installed, tight fit!
    Conclusion:
    These were a blast and they've been my go to speaker for casual listening the last few weeks!
    Everyone that has heard them has fallen love with them, so I'll be very interested to hear how they hold up at Indiy. The bass is shockingly powerful for 3 1/2 inch diaphragm, they put out comparable bass to many 10 inch sub offers that I've heard and built in the past, they will easily trounce most 8" on the market.
    This is the first time I've used a "full range" driver and I'm very pleased with it, working with the top and was challenging but once I got it rolled off and minimized the break up it really smoothed out and is quite surprising how much crisp clear treble this driver can produce. Imaging is excellent, they sound great near field as well as 6 to 8 feet away, they have no trouble filling a room with sound and I have even fooled a couple people into thinking they were hearing the Rally Sports when in fact it was the microfarads.
    Most notable, ironically, is their bass performance. In fact they have too much bass, due to the limited excursion capabilities of the passive radiators as well as the very small air volume, tuning frequency is high and the bass response quite boosted below 120Hz. Though they rolloff below 45 Hz, that's enough to encompass the majority of all content in just about all my reference music and other music that I enjoy listening to regularly. This has been an eye-opening venture into the micro speaker category, and I'm looking forward to doing some more small builds in the future, and another version of these with slightly more airspace with a more capable passive radiator.
    Thanks please let me know your thoughts and if you have any questions!
    Javad
    Javad Shadzi
    Bay Area, CA
      Dare I say- those look store-bought!
      Very well done!
      It's gonna be tough to judge this weekend,
        Those are great looking speakers. Sent from my iPhone using Tapatalk
          Very pretty wood! nicely done.
          Twitter: @undefinition1
            Impressive! Very nicely done.
              Looks great Javad! I've been thinking about using that woofer for a project. It's pretty crazy what it can do in such a small space. The efficiency is the trade off but if used in the right situation not a deal breaker. Did you happen to save a DAT's sweep on it? If so, could you send me a copy, thanks.
              My "No-Name" CC Speaker
              Kerry's "Silverbacks"
              Ben's Synchaeta's for Mom
              The Archers
              The Gandalf's
                Great job, I love that wood and finish. Nice idea on the mid/ tweeter back cups I may need to try that.
                John H
                  Nice work! Is the Danish oil all you used on it finish wise?
                  -Kerry
                    Thanks! That and some furniture wax.
                    Javad
                    Javad Shadzi
                    Bay Area, CA
                      Truly awesome. Love it. I've been wanting to use that line of woofers for a while, just haven't had time to get to it.
                      Keep cranking em out!!
                        WOW! Well done sir!!
                          Crikey, mate - work of art indeed.
                          Tangband W6-sub
                            The Mahogany Preservation Society is going to hear about this. Using their namesake for audiovisual gratification, tsk tsk!
                              Everything you build is so well done! Again, very nice job!
                              Projects:
                              Breezy Monitors: http://techtalk.parts-express.com/fo...reezy-monitors
                              transcenD: http://techtalk.parts-express.com/fo...5035-transcend
                              Summits: http://techtalk.parts-express.com/sh...75-The-Summits
                              References: http://techtalk.parts-express.com/sh...-My-References
                              Vintage Style 2-way: http://techtalk.parts-express.com/sh...-vintage-2-way
