Purrsay - Silverline
  • #16
    Just finished the bracing on 2 LCR's I decided to keep the center the same. Maybe with an optional baffel and top mounted tweeter for use as a horizontal. I have to cut all the supports for the last LCR. Whenever. No veneer or final touches until I get the working crossover. Next in line. Alll the rest can be done indoors now. Lots of time before the holidays this Winter. The drivers I have left will be used as surrounds. 2, 6.5" 8ohm HDS, 4, 4.5" PPB Peerless 4ohm. I would have to find 4, 4ohm silk dome tweets. Dayton does have them. Better order soon!! There goes my full driver stash!!
    • #17
      Originally posted by PWR RYD View Post
      I've used that Peerless buyout woofer a couple of times. Really great sounding woofer with excellent sensitivity. It could easily match up to the silky in an MTM without a midrange driver. Its only short coming is that it won't extend very low in frequency. LouC used it in about 22 Liters in his Lecbos project with a F3 of about 70 Hz. I recently used it in an MTM in 17 liters with about the same F3. I matched it up with the Dayton Audio ND25FW tweeter. Awesome sounding speakers for very little money. I'd publish my design but the woofer is no long available :( wish I could buy 100 more of them...
      Always a good idea to publish a design. There are plenty of those floating around or sitting on shelves somewhere. I think I may even have a pair somewhere. Just basic information of size, driver location, tuning etc. is enough for most people.
      • #18
        By the way, I calculated the efficiency of the woofer to be somewhere around 90.6 dB, higher than PE's specs. I think a silky will be just able to match up in an MT or MTM.
        In a 17 liter net enclosure, tuned to 57 Hz, I see an f3 of 54 Hz. This is in an alignment using parameters which are an average of 4 tested units.
        Where does your f3 of 70 Hz come from? Is this calculated or tested? What parameters did you use?
        • #19
          70 hz?
          I think that was a quesstimate??
          I was hoping for some low frequency extension by my eq.. I be happy with 80 hz :/
          I've heard them briefly on another crossover, sounded ok..
          • #20
            I'm was positive that I seen that they were 90.5 db.
            I checked back and it was 89.5!!
            I had a few 2 ways. I wanted a 3 way. I can always pop in other drivers down the road. Hopefully not!
            • #21
              Calculated F3 of 68 Hz from Unibox using the average of my four measured woofers. I'll have to search a bit to find those T/S's. If I remember correctly the box model didn't change much using the PE published parameters. I have enough subwoofers available that a low F3 isn't a design concern.
              Craig
              • #22
                I believe my calculated sensitivity with the two woofers in series was about 90.5 dB/2.83v/m
                Craig
                • #23
                  Changed name to Phantom Edge!!
                  In the process of sealing the MDF.
                  Maybe a start to a passive cross on the weekend.
                  • #24
                    Had time again! Left and Right are mdf sealed, ready for vinyl wrap and baffel sealing tape. I initially used Rust-Oleum for the first to seal it. Found it was way cheaper to use water and wood glue for the other two! Practice for paint, if I ever do.. The edges are routed for aluminum corner edging. Had a chance to start a crossover in WinPCD Like someone mentioned, I will be padding down the mid substantially. Too bad I can't use the mid to bump the lower frequency without upsetting the impedance load. Non the less I will see what I can come up with soon. At least the mid is down at 86db in the low freq. end slowly rising. Getting close to the holiday season. See if I can get it done. The 3rd channel is still in pieces eating to go through the same process. B way quicker.
                    • #25
                      Had a few mins. Went with a 2nd order Linkwitz Riley. I will have to think about it later. It looks good on paper!! :/
                      • #26
                        I had not looked at this thread for a while. I had done this alignment a number of years go and initially got it off my old erratic computer, not realizing that I was comparing apples to oranges in that my model was for one driver while your design calls for two. So you are right and I need to clarify my statement:
                        In a 17 liter net enclosure, for one driver, tuning to 57 Hz I see an f3 of 54 Hz and for two drivers, tuning to 60 Hz I see an f3 of approximately 70Hz.
                        Like Craig says, if you are using a sub, I see no problem. Personally, without a sub, I think I would build this a little larger to get the lower f3. A moot point now.
                        • #27
                          It does look really good on paper - don't forget to add the DCR to your inductors though, that resistance will affect the response.
