Going after JaWZ!
  • Going after JaWZ!
    Poplar plank for front baffles Back from Home Depot Let the gluing begin!
    Looking good Steve glad to see this coming together! Javad
    Javad Shadzi
    Bay Area, CA
      ​So, I'm making progress, but slowly. Posting has been even slower, but time to catch up...
      Forgot to include my 'master plan' I always start with. It is subject to change (or being redone when the dog eats it - as she did for the matching subs)
Name:	4 Plans.jpg
        When I started, I didn't have a router. (I've added several very useful tools along the way). So, I used brace supports vs. dado joints for the braces.
Name:	5 Brace supports 1.jpg
ID:	1353596 Click image for larger version
Name:	5 Brace supports 2.jpg
          Next, the braces themselves. It is an MTM design. Those 3 sections are all part of the main enclosure. The bottom will be sealed off, and hold the xover.
Name:	6 Braces 2.jpg
ID:	1353599 Click image for larger version
Name:	6 Braces 1.jpg
          I added a layer of MDF at the bottom of each speaker to help with stability. As you can see, I had one solid piece and then some other scraps. I hate to waste!
            Remember how I said I bought some useful tools along the way. This was before I had any long clamps. My dad sells yard-ornament concrete and had dropped some off at our house. Whatever it takes! This is gluing the front baffle. ... The box is 3/4" Red Oak plywood. Click image for larger version
Name:	7a Gluing front with concrete.jpg
              I cut the front baffle piece wide. This is flush-trimming it.
Name:	7b Routering front.jpg
              And this is what happens when the router bit throws its guide bearing.
Name:	7c router bit damage.jpg
              I've had various ideas and suggestion for how to cover this up. I may just end up using some wood putty. ... I think if my 'speaker line' had a name, it would be 'Real Life Speakers.' In terms of sound, I want real life 'in the room' dynamics. That's why I'm going with a CD/waveguide and pro drivers. Also, I'm not the best woodworker, so there are always 'issues' when you look close. But, the speakers perform well. Sort of like, real life. We've all got issues when you look close!
                For the front baffles, I'm attaching a piece of poplar at the top, where the drivers are. I got this nice piece, but it needs to be cut and glued together to get the right size.
Name:	10 Poplar - marking.jpg
ID:	1353609 Click image for larger version
Name:	11 Poplar baffles - glued.jpg
                You can see what I was using for a 'workbench' in the left photo!
                  Time to cut driver holes in the plywood layer.
Name:	12 Holes for drivers.jpg
                  I didn't router the back of the plywood, so I made some cutouts to let the speaker 'breath.' Don't know how much it really helps, but might as well! I left 'tabs' for the screws, so they could go through the poplar, into plywood.
Name:	14 Breathing room cutouts.jpg
                    I decided I needed some upgrades... No more concrete yard ornaments. I've got clamps! AND, an actual workbench. This is attaching the poplar piece to the front baffle.
Name:	15 Clamping poplar baffle.jpg
                      You always love it when these show up at your door!
Name:	9 Parts Express box.jpg
                      I went with drivers that JavadS had used and recommended.
                      FaitalPRO 8FE2000 8" Professional Midbass 8 Ohm
                      B& C DE250-8 1" Polyimide Horn Driver 8 Ohm
                      SEOS 10" Waveguide
Name:	16 Drivers in cutouts.jpg
                      Starting to come together!
                        I'm putting denim insulation on the back wall. I'll fill the cabinet with acoustic stuffing.
Name:	17 Denim insulation.jpg
                        I'm using aperiodic vents, per Wolf's recommendation. You can see one of the shower drain covers I'm using in the upper left.
                          I wasn't ready to glue the back on when we did measurements for the xover. That's the reason for the clamps. ... "We" being Wolf - with me just being a gopher! He is building the xover. I don't know a capacitor from a coil!
Name:	17 Measuring for Xover.jpg
                          In the background, you can see a sub Rick Craig of Selah Audio designed for me using an 8" SB Acoustics driver. I told my daughter she could paint it. We had recently moved to Indiana from Arizona (where she has always lived). She's more than a little homesick.
                            I later got things ready to glue the backs on. It sure is nice to have clamps...
Name:	18 Gluing back.jpg
                              The speakers will go down to about 76hz, so I need subs. Rick from Selah has designed two subs for me prior that sound great, so I asked him. I found some more nice poplar to match the mains.
Name:	19 Spacing sub holes.jpg
                              That's a 12" SB Acoustics driver. ... Since Rick is helping with the subs, the name of the speaker set is now 'JaWZ Pause.' ('Selah' is a term found in the Bible book of Psalms. Scholars aren't sure what it means, but one thought is it indicates a pause in the singing (Psalms are songs))
