Going after JaWZ!
  • #16
    So... add corner reinforcement all around the inside of that edge then you can put a big bevel all around it which will cover up that error. Also- your bracing scheme adds very little side-side strength. I'd cut some sticks and add them across the "windows" laterally. If you cut them slightly small and use soft caulk to secure them, you'll have the benefit of damped bracing (which is more effective than rigid).
    • #17
      Just to inform of the initial preparation....
      Here is the simulation and the preliminary xover, using in-box measurements:
      PXO vs SXO (except above 10kHz):
Name:	PXO vs SXO.jpg
      Parallel sim:
      Series sim:
      And the networks:
Name:	Steve Xover.png
      And the initial measurements:
      I'll be mocking up both at Steve's place, taking measurements for verification, and he'll decide which he prefers or if changes are needed.
      More later,
      • #18
        I appreciate the suggestion. I want to make sure what you mean... Are you saying to add "sticks" horizontally? Is so, I assume midway between each existing horizontal brace? ... Again, thanks for the input.
        • #19
          More later,
          Can't wait!!
          • #20
            Yup- exactly.
            • #21
              badman have you used the DE250? I am contemplating a build using the FE8 (or 10) and the Peerless DFM-2535 (part #264-1420). Any subjective comparisons between them? As if I recall you were in the thread about the peerless. the B&C is more than double the price, but wondering if the Peerless could keep up or if the DE250 is worth the extra cash. Not trying to hijack the thread Wolf, just curious on the horn selection!
              • #22
                I haven't used it but all indications are that it's excellent. It's a larger diaphragm than the peerless, so you can push it a little more at the bottom end, where the peerless seems to have a little better top end. Most of the time, that's a win for the B&C, unless you're crossing higher. The Faitals are really nice drivers for the money, and should be able to work well with either comp driver on a decent waveguide, like the seos used here. I prefer larger waveguides wherever possible as they make crossovers a lot easier (which tends to mean better end results), but if you're using something like the 10", either is a good option, the waveguide is on the small side for the L.F. abilities to matter much, you'll likely want to cross near 1.5kHz either way. Low for a pro system, but should be fine at home SPLs.
                • #23
                  Ok thanks for the feedback.
                  • #24
                    Steve and I got together this evening for a listen. He stuffed and installed while I mocked the xover up. I set up the SXO xover first, just because, and off we went. I dialed a couple components a smidge just because I didn't have exact values to match the sim and went with what I had. More or less, a slight shift in both the horn's padding, and notch to reduce the last bit of horn honk. Then we ran them through the mill- with just about everything we felt like.
                    Let's just say we never mocked up the PXO. We were both very happy with where they came out that we just didn't feel the need to try the other one. I left the mocked up networks at Steve's to allow him to listen for an extended period of time and make sure there wasn't anything found to be out of character.
                    Here's where we dialed it in, and the modeled response follows just to show the outcome and the predicted system impedance.
                    (The 8.2 ohm resistor is a 7.5ohm + DCR.)
                    Likely time to order parts!
                    • #25
                      It didn't happen if there's not pictures, right. Here are a couple. Really loving the sound!!
                      • #26
                        Javad- I see you liked this post. Since you have the drivers in those (last I knew), you could see what you think of the xover. I'd like to know what you think! I know your baffle is wider, but that should be a minimal difference.
                        • #27
                          Really good looking set of speakers and nice work on a series crossover - very cool!
                          • #28
                            Javad- I see you liked this post. Since you have the drivers in those (last I knew), you could see what you think of the xover. I'd like to know what you think! I know your baffle is wider, but that should be a minimal difference. Later, Wolf
                            Ben all my work with this design in the SFE-812 was active, the response here looks good for a passive design for sure. Thanks! Javad
                            Javad Shadzi
                            Bay Area, CA
                            • #29
                              I just figured it would be easy to try it.
                              • #30
                                I just figured it would be easy to try it. Wolf
                                Ohh I see, unfortunately I don’t currently have possession of those speakers, wish I did would be fun to try this
                                Javad Shadzi
                                Bay Area, CA
