Crossover inductor layout
  • Crossover inductor layout
    I'm getting ready to build a pair of Speedsters and I could use a little sanity check on the crossover layout, specifically the inductors. My plan is to use the pre-drilled 3.5"x5" crossover boards from PE since space inside the cabinet is at a premium. I cut a scrap of cardboard to size and began laying out components. Any issue with how I have them? If so, how can I fix? Thanks in advance. Sent from my SM-G950U using Tapatalk
    Nice job orienting those inductors. That will work. If it's not too late, consider sliding the left one up a bit... like this...
    ~Marty
    Baby Eidolons
    Sapphos
    Cables (Post #54)
    Other speakers (Post #21)
    Design Thoughts (Posts: 6,10,13,33,35)
    Boundary Augmentation
    Dispersion/Interference
      You COULD rotate the left one 30*-45* ccw and the bottom one cw 45*-60*, but . . . there's no problem the way you've got them now.
        Thanks for the help. Once I have the crossover boards, I'll lay it out and play around with it a little more. I'm excited to get these built. Hoping to get in the basement this weekend and start gluing the cabinets together. The DIY Sound Group flat packs make life so easy. I've got a couple nice pieces of bamboo I'm still deciding if I want to use for the baffles, or save them for a different project. My son has taken an interest in listening to music so he and I may do a set of C-NOTEs for his bedroom and I'll save the bamboo for those. Sent from my SM-G950U using Tapatalk
          C-Notes are nice, but IMO the Classix II are probably a bit more fun to listen to. YMMV
          (OOPs !) - I just realized that the Classix are $85 EACH! Thought is was for the pair. My bad.
            I picked up the boards yesterday. Playing around today and came up with this layout Any thoughts would be appreciated. Thanks Sent from my SM-G950U using Tapatalk
              FWIW, this forum sector is for finished project photos, and links to write-ups. The TechTalk forum should be where queries are asked.
              Just an FYI,
                Absolutely nothing wrong w/THAT, but . . . you COULD lay the big one down, and stand the tiny one up, aimed at the big one. Coils always SEEM more secure to me lying down, so (if I can) I prefer to stand the little guys up instead.
                OR, you could lay down the bottom left one, 'cause it's probably the least stable (due to its height-to-width "aspect ratio"). Then I'd aim the little one toward the bottom left. (The BIG coil just wants to roll, while the med. size one wants to tip over. Imagine the forces acting on the mass if a non-destructive "accident" happened, like dropping the completed speaker onto a carpeted floor - from 3-4 feet. Even if there was no driver damage, would your XO survive?)
                  The orthogonal alignments of your coils are perfect. Clearly you've been paying attention. Nice job. But Chris R. does make a few good points about structural strength and stability. I typically use BOTH zip ties AND hot glue for all my coils to avoid the issues Chris is talking about. It looks like you've got a good grasp and you know what you're doing. Cheers.
                  ~Marty
                  Baby Eidolons
                  Sapphos
                  Cables (Post #54)
