Matrix Revolution
  • Matrix Revolution
    Background (a little long and rambling):
    Over the years I have got a lot of mileage out of the Matrix project. As I was getting into audio back in the 1980's (wow, I'm getting old), I was an Infinity fan - not so much the SM series but the higher end lines with planar tweeters and either planar or dome midranges. Later on I discovered NEAR (which was later bought by Bogen) and that introduced me to the strengths of Aluminum cone woofers. Back in 2007, I did a monitor design with the Dayton RS150's and Bohlender Graebener Neo3PDR that combined a planar tweeter with an aluminum woofer and I really enjoyed the combination. After winning a pair of Dayton RS150T's as a door prize (thanks PE) and acquiring a pair of BG Neo8 drivers (reminded my of the old Infinity planar mids), I decided to buy another pair of RS150T's and build a slim (7" wide) floorstanding speaker which I called "Matrix" due to the rectangular array of openings in the front of the BG Neo drivers and the popularity of the movie (which evolved into a trilogy just like my project). I later revised the design when I had better measuring capability, and I followed the movie naming convention and went with "Matrix Reloaded". http://techtalk.parts-express.com/fo...atrix-reloaded
    Father time along with 2 sons and their friends have been hard on the RS150T's. Two RS150T's succumbed to cone damage and 1 to an overly enthusiastic Ben Harper listening session. By the third replacement, I had a pair of Dayton ND140's on the shelf courtesy of the PE tent sale. Curt Campbell had used a pair of ND140's in a very similar cabinet in his Aviatrix project, So, now I had a choice. Buy another RS150T or buy another pair of ND140's and try to address the 1 weakness of the original design. Pretty much everyone who ever heard the originals felt that they could use a little help in the bass department. I decided to take the plunge with the ND140's and take the next step in the evolution "Matrix Revolution". Hopefully this will be the final iteration, because I'm not sure what I would call the next version...
    Driver selection:
    The Bohlender Graebener Neo3PDR and Neo8 are planar drivers that resolve a lot of detail with very low distortion. Even though the price of the drivers have risen considerably over the years they still compete with much more expensive drivers. The Dayton ND140-8 is a 5" woofer with a single piece aluminum cone. The parameters allow the woofer to work well in a small sealed enclosure or tuned between 35 and 40 Hz. in a relatively large vented enclosure, as in the Aviatrix. The optimal vented alignment is almost identical to what I had in the original design, so with the exception of the crossover, these would be a drop in replacement. The screw holes in the frame even line up with those in the RS150T. The two ND140-8's are wired in parallel for a nominal 4 ohm impedance.
    Cabinet Design:
    The cabinet is 7" wide by 43.5" tall by 14.5" deep. Front and rear walls are 1.5" thick mdf (2 layers of .75" thick material). Sides, top and bottom are 0.75". The net internal volume is approximately 42 liters. A 3" diameter by 6.75" long rear port tunes the enclosure to 38 Hz, which will give an f3 of approximately 35 Hz. The portion of the cabinet below the woofers is heavily damped with Ultratouch denim insulation and Whispermat sheets to try to damp out potential pipe resonances resulting from the tall, slender cabinet. Driver layout is shown in the Matrix Reloaded thread linked above.
    Crossover design:
    The Neo8 is truly world class at producing low distortion, highly detailed upper midrange and lower treble. It's weaknesses are that it can't play much below 800 Hz and has very limited vertical dispersion. My strategy to deal with this remains similar to the original design. Crossover points are approximately 1 kHz between the ND140's and Neo8 and 3.5 kHz between the Neo8 and Neo3PDR with approximately 2nd order acoustic slopes. The idea is to create more overlap between the drivers so there is a less abrupt dropout of the midrange as one moves away from the height level of the Neo8. The schematic shows a simple second order filter on the woofer, first order high pass and third order low pass on the Neo8. The Neo3PDR has a second order high pass filter with a small inductor in series with the tweeter. This has the effect of filling in a response dip between 5 and 10 kHz, but rolls the response off above 15 kHz.
    Measurements:
    The on axis frequency response is flat within approximately +/-2 dB from the lower end of my gated measurement accuracy (about 300-400 Hz) to 16 kHz. The measured individual driver responses (shown on the same graph) indicate actual crossover points of 860 Hz and 3.1 kHz. The horizontal off axis response is quite remarkable. From 400 Hz to 8 kHz, the measurements indicate very nearly uniform dispersion. In the case of the Neo8 and Neo3, this is understandable as the drivers are the same technology and same width, but I was not expecting the transition from the ND140 to Neo8 to be that uniform. The impedance plot shows the cabinet tuning frequency of 38 Hz. Although this design features two 8 ohm drivers in parallel, the minimum impedance is right at 4 ohms at 130 Hz. This should be a reasonable load for most amplifiers to handle.
    Impressions:
    The current incarnation of the Matrix has been a lot of fun to listen to. The spooky micro detail of the original is still there, but the bass is now also fully present and accounted for. These were demoed at DIY Iowa 2017, so others may chime in with their impressions.
    Showtime Crossover Schematic On axis frequency response
    Sehlin Sound Solutions
    Cool! Now THAT'S a narrow cabinet.
    Twitter: @undefinition1
      I think the Neo8 models available these days are the S (higher sensitivity) and PDR. Which would drop in?
        The Neo8s has an 8 ohm impedance, so it would need a completely different crossover. The Neo3PDR has 1.5 dB less sensitivity than the Neo8, but better horizontal dispersion. The net effect might be pretty minimal. Either okay as is or might need to decrease the 5.6 ohm padding resistor a little.
          I was really impressed by the sound of these at the Harris Center. One of the best speakers at the show, in my opinion. Very detailed. The transition from Neo8 to the ND-140 was very smooth and much better than any of the small cone woofers that I have tried to mate with them. I have a pair of Neo3's and Neo8 PDR's, so it looks like I will be picking up a quad set of ND-140's in the near future. Have to make sure I get the 8 ohm versions.
          Thanks for posting the detailed info.
          Bill
          SideTowers: http://techtalk.parts-express.com/fo...corundum-build
            I appreciate the kind words Bill. I have been really happy with the ND140's. I hope I will get to hear your speakers when they are done. I am curious how the Neo8PDR will compare to the Neo8 in this application. Hopefully, it will give this design some additional life since no one is carrying the Neo8 anymore.
            I have a pair of Neo8s, which were a very generous door prize from PE, but I would really like to try those with a bigger woofer crossed lower.
              There is a nice Peerless 10" woofer on sale for the next 2 days Scott ;)
              Craig
                Same woofer used in the Tarkus which I built, 60l tuned to 32 (I think) and was outstanding in my limited experience that PWR RYD mentioned.
                  They also model very well in a sealed enclosure.
                  Craig
                    Those Peerless woofers were my first choice for the Indium 7 project - but they were about $75 each at that time. PE wanted me to look for something lower cost, and I wound up learning that the SD270 could do very well for $40. At $50, that Peerless is a very good buy. My brother has a pair that I will have to eventually design something for.
                    I will pass on them, as I have a lot of other parts on the shelf that need to be deployed and I have a thought on how to get that done. The acronym is DABB ...
                      I am putting together some preliminary construction plans, going over drawings and deciding what materials to use. In looking at your cabinet drawing posted in the other thread, I was unable to find a rear view showing the port location. How far up from the bottom of the cabinet is the port located? I would image it has to be up about a foot or so to clear the damping material. When I begin construction, I don't want to put the port too high as this might affect performance. Thanks.
                        The port is on the rear, 12" down from the top of the cabinet. It is aligned behind the center of the Neo8. Since the woofers are down low and the very bottom of the cabinet is heavily stuffed, there isn't really a low placement that makes sense.
                          Thanks for the info, Scott. I would not have guessed that it was up this high. Maybe it was just where I was sitting, but they seemed to dig quite deep for such a small cabinet with only a couple 5 inch woofers. When I start building, I will be sure to put the port in the same spot. Bill
                            The venue (particularly the stage floor) tends to accentuate bass, but they do also have pretty stout extension at home. The ND140 is quite capable for the price and light weight. Holding one in your hand does not prepare you for what it can do...
