My take on Dragon Foals CNC
  • My take on Dragon Foals CNC
    Starting my project as a Christmas present for stepson. Going to cut the box on my CNC out of plywood with a slot port.
    Are you changing the dimensions?
      internal it will be 6" x 6" x 5.5" for a total of 3.1 liters correct?
        Volume is not the only consideration. The way the edges interact with the response due to distance is also a factor. I can look up the dimensions via wayback, or see if my write-up disc has a backup on it. Are you lining the port? It needs it. You can proceed as you like, but changing the design will throw reason of dissatisfaction back on your part if you are unhappy with the results. This is why I was giving you info in the blog replies. The write-up was in full awhile back, but due to forum updates and revisions has been truncated, omitting valuable information. It is not all there.
          Yes originally i looked for the build and could not find it, i did not know it was due to updates just thought i could not find it. I ordered 6 of the drivers as i'm going to build my step son a Ipod/Alexa speaker to start with. I will then play with a set of book shelf / point source after and later a sound bar. If you could find any additional information such as the size of the box and driver placement i would be most appreciative. I have 6 drivers and enough crossovers to build 3 to your specs i could find and a few extra odds and ends to play with sound bar.
            I'll try and wayback it first...
              I've got a pair of "Dragon Foals" built by Wolf himself.
              Incredible sound!!!!
