What I am making from Wolf's "Zinger" design
  • #16
    One.
    • #17
      Two. I still have to cut holes for the ports and terminal cups, and the front rim lumber has some thickness variation requiring sanding.
      • #18
        • #19
          Excellent work, you are on the home stretch. Watco for the finish?
          My Builds - Overnight Sensations w/ Voxel - Speedsters in surplus boxes - Zaph B3N's in bamboo - Classix II in BR-1 cabinets - Dual TPA3116 D2 amp in an old music box - Mariposas
          • #20
            Wow those look great djg. Can't wait to see how the grain pops with some finish on it. You work fast!
            Craig
            • #21
              You have made short, quick work of this build.
              Looks great in mahogany with the recessed black face, very vintage, very Original Large Advent-ish.
              Andy.
              BTW - that is a heck of a desk top build...a bit larger than most you see (mine are Heliums)
              • #22
                I'm definitely hooked on PSA veneer. I did both boxes in a few hours. Right now, some Minwax Ipswich pine stain I used on my new window jams looks really nice on a sample. I'm not sure how shiny I want to go.
                Desktop, LOL. Yeah, they fit in the theme of Wolf's name of "Zingers", a large engine stuffed into a silly small chassis. We'll see how they work in that venue. I may need to back my chair up a bit.
                Thank Wolf for the inspiration and design. I know I have changed his box layout, especially the recessed baffle. Done purely for looks. I'm pondering how to do a foam grill that will clear the woofer surround.
                • #23
                  I'm thrilled you chose my design for a build, djg. I also hope they suit you well and make you smile!
                  • #24
                    I've been wanting to make a retro speaker and also build one of Wolf's projects. This seemed to click.
                    • #25
                      They're looking good!
                      • #26
                        Put the stain on, too wet to handle. I'll get some decent pics after finishing. This will take a while. Most of the info on the web on mahogany finish was about deep dark red using lots of products. This is a light stain, I like it.
                        • #27
                          Minwax has a varnish that's not Poly based, only Sherwin Williams stocks it. I have some left from a bed frame I made, I'm going to use it. Satin.
                          • #28
                            Great build djg. How thick is the veneer on the baffle and the enclosure. PSA seems to work pretty good. Any special tips for first time user's?
                            Myles
                            • #29
                              I shellac the particle board and sand it smooth. I cut the veneer with regular scissors at least 1/2" oversize. I make sure the surface is clean and apply and burnish it with a slightly rounded corner of a wood scrap. I feel around the veneer with my fingertips to be sure it's going to cover before I press it down. If you put it on crooked you have a problem, the adhesive is very aggressive. I use a flush trim bearing bit in a router to trim. The waste veneer sticks to the bit and generally needs removed after every pass. The baffle is painted, the picture frame surround is 1/4" solid mahogany.
                              I buy from here.
                              Mahogany Wood Veneer 3M Peel and Stick Adhesive PSA 2' X 8' (24" x 96") Sheet | eBay
                              • #30
                                Tomorrow or the next day before final assy.
