My Current Project...(Teasers...)
  • #76
    Originally posted by fdieck View Post
    Wolf.... you have got to be kidding. You are neglecting wiring inductance, and capacitor self inductance. These stray inductances will interact with your high Q trap circuits and provide all kinds of unanticipated resonant circuits. The same goes for the interaction between the trap circuits which have high Q (little resistive damping) networks in series. There are lot of amps that will no like this load.
    The load is just fine, as the swing is minimal. You can see this in the system impedance plot. What I've done here has been done many times before.
    John-
    This is exactly how I designed the Zingers, and they are just fine. Single point in space, and 2 measurements on one axis.
    • #77
      Originally posted by rpb View Post
      Are the measurements gated? I'll find out soon enough when I load them, but I'd like to see if gated makes any real difference. I find them easier to interpret, since they smooth out some of the peaks and dips.
      I see dual binding posts in the pictures. Do you plan to keep the x-over external?
      Sorry I forgot that part. Yes they are gated just above 6ms.
      Your results may vary.
      • #78
        John-
        Whatever.... There no point in arguing with people that just don’t want to learn anything. If you really think that is a valid crossover because it looks good in a simulation program have fun. I started not to post it since I figured it would fall on deaf ears.
        • #79
          Do you still have the measurements? Change that gating to before the first reflection, and post them. They will be much smoother. The drivers I measure are not plus or minus 3dB in the 400hz to 1k range.
          • #80
            Can you borrow xo parts, and try filters, and measure them?
            • #81
              Originally posted by jhollander View Post
              Wolf you should add in the woofer offset to get the phase tracking right. The little m next to the driver S1 would indicate it's modified. My sims use a woofer offset of 1.39 inches in XSim
              That offset seems excessive for a 5.25". I would speculate that it is half that.
              My previous xo works well with the new files, although I changed some values to make the mid-bass measurement look smoother at what I think may be the splice point..
              • #82
                Why speculate? The T & W file is included, you can calculate the offset yourself, both in PCD and XSim.
                John H
                • #83
                  Note when calculating the offset remember not to mix the as measured and minimum phase. There are multiple files posted in this thread. It's interesting to note that the as measured and minimum phase files have close to the same offset.
                  John H
                  • #84
                    The latest measurements I posted are the gated unmodified measurements. John has posted his corrected measurements using those files.
                    Sort of... I have a couple bins of XO parts up here I can pick from but I don't always have the values I need. I make due. I have gone through probably 5-6 variations of designs thus far, including my own, Johns and yours and even a bit of a combination and have been slowing tweaking here and there.
                    Yes I am going to do external crossovers. I got tired of removing woofers a million times to change xo's. This is so much easier.
                    The number of designs that have been posted is overwhelming. The biggest pain has been lugging one of these back and forth to the lab from home 4 times now. They are not small and they are not light...and they are fragile lol. I have bumped into my share of doorways etc in the past and nicked up boxes. I would rather not do that with these.
                    The latest I mocked up last night really brought them to life. Phase looked good, breakup was fairly well controlled and the XO moved up to about 1700. I will probably listen to this for a couple days and see if there is anything else I can do to improve more. The only changes I might make are to that breakup if it seems to be an issue...but so far I think it's ok. Time will tell, I had a couple hours on them last night.
                    I never expected so many designs to come forth. This is pretty cool, a million different ways to get near the same result. I wish I could mock them all up and give them each a week long session but that is just not practical. I appreciate everyone's input so far. I have learned a lot during this build that I didn't realize I didn't know...
                    Once I make a final design decision I will bring them back for final measurements. I will also take in-room measurements when the whole system is done and share everything.
                    This is what I have as of now. The breakup is the only thing that has me slightly worried as Wolf pointed out before. I really don't think I notice it but I still might try to get it lower just to be on the safe side. It could very well be audible and I just don't know what I'm listening for. Nothing stands out as obvious or "wrong" at the moment during listening tests. Image is absolutely pin-point and the sound stage is massive. I couldn't believe the difference after the first few mock ups.
                    Measured:
                    Click image for larger version  Name:	 Views:	1 Size:	15.4 KB ID:	1419872
                    Modeled:
                    Click image for larger version  Name:	 Views:	1 Size:	83.7 KB ID:	1419873
                    Click image for larger version  Name:	 Views:	1 Size:	87.9 KB ID:	1419870
                    Click image for larger version  Name:	 Views:	1 Size:	32.2 KB ID:	1419871
                    • #85
                      Minimalist, updated for new files, break up pushed down, 1.8K x-o, decent phase tracking, impedance etc. The dip at 3.1K is likely the faceted baffle. I'd check off axis before investing more parts
                      John,
                      Yes that dip is the baffle and it does smooth out off axis. I might play with third order on the woofer next, I feel like I am getting really close.
                      • #86
                        I never said I didn't want to learn anything. I just don't see your problem with it. The LC notch (trap) across a driver is swamped by the inductance of a lowpass coil. You also have the R factor of the coil involved. The phase swing is minimal, and only dips to -45 in one place and it's not a bad impedance in that region. What I did is simple, I paired a broad-band notch with a centralized notch in the same bandwidth, and the low pass coil increases the net impedance so it does not tend towards zero + DCR. It will never get that low. A lot of amps do not like the tank + trap arrangement, yet it exists, and used heavily for enough suppression.
                        So- what don't I know here? I do know that tank + trap will effectively suppress aluminum breakup, and I've done it several times.
                        Please- school me,
                        • #87
                          I looked at it more closely it probably is fine. I just don’t like circuits that present complicated loads at RF frequencies since high bandwidth amps, chip amps without out RC damping networks, and class D amps can sound bad or oscillate with complicated loads like this. I would put a few ohms in series with the caps on the parallel LC networks at least. I used to do EMI suppression design at work and mod and design power amps so this is not just paranoia. You might even even try a 5 ohm in series with 0.1 uF network across the input to the crossover to provide the amp with resistive load at high frequencies.
                          PS I put damping material on aluminum cones. I can’t even listen to them with the trap circuits I have tried. The SB acoustic “ceramic” driver really benefited from cone treatment. Rudy Bozak had sense enough to put latex paint on aluminum tweeters over 50 years ago.
                          • #88
                            I think the Ceramics are wonderful sounding on their own with the right xover. I would not coat them if it were me.
                            I've even used notches similar to these on composite sandwich cones, to reduce the breakup as they are very stiff- even if well damped.
                            The only part values that enter into the ultrasonic range here would be the tank caps. The others are being low-passed and shunting breakup within the audible band.
                            I agree that a resistor on the tank caps might be beneficial, I just did not model them in. I do not feel the shunt legs in this simmed network will offer any negative effects on their own as used.
                            I knew your intentions were likely valid and true about how you felt, and that you likely had good reasons for them. However, I could not see anything wrong with what I did. Tanks are a bit troublesome ultrasonically at times, as the caps will pass signal above their value point which means ultrasonics. Some amps do not like these, but I've not come across one of my own that can't cope with their usage.
                            It does however give me pains that you thought of me as a know-it-all and not someone whom is willing to learn of something he does not know. I've been wrong before, and will likely be again. I do strive to be as accurate as possible. I try to learn as much as I can about this stuff- I love it, and the camaraderie.
                            Take care, Fred,
                            • #89
                              Measured:
                              Modeled:
                              I didn't post a complete x-over to try. (Yet) Here's something to look at. Here's your current xo, and my xo that uses a lot more parts. There's a voicing difference here that would be very significant. One is a bit laid back, (yours), the other is rather aggressive (mine). It's tough to know which is preferred, but once you listen, and see measurements of what you listen to, you get a pretty good idea where you want the response.
Name:	a voicing comparison.jpg
                              • #90
                                Well after some fiddling today I made one minor change to the current setup, I upped the woofer L value to 3 (3.2 measured, you were right about those Jantzen coils Wolf...) which brought the break up down and along with the parallel cap (is that 0.33 a tank filter, or is that only filters that go to ground?) it flattened out and peaks at about 56 dB now. This did bring the theoretical XO point down a smidge but I am confident these tweeters will be fine.
                                FYI if anyone sees anything that stands out as blatantly stupid in any of my sims please let me know.
                                I think I will add a little more damping to the cabinets before its all said and done but after sitting here for a couple hours already tonight I really don't see an immediate need for any new changes. The room and my electronics I think are the biggest limiting factor. I need to rethink my wall treatments and add some bass traps. That will happen once the subs are done.
                                Stay tuned. More updates on the stands soon, then the subs will start. Is it bad when I have 3.5 sheets of MDF in the shop for two 2 cubic foot subs and I am worried it may not be enough?
                                Where is Joey Butts and all his ridiculous bracing when I need backup here with all my overkill lol.
