My Current Project...(Teasers...)
  • mattp
    Nice anechoic chamber. So the graph above was in the chamber? Any gating? I'd love to see some detailed pics about the chamber so we could diy one...
    It's likely the 'chamber' they have at PE.
    It's basically a booth like you get into at the ENT for hearing tests, or for recording vocals. They have added the wedges to the walls, and the former window is the mic/driver interface depending on the function intended.
    Ben is correct, this is the chamber here in the lab at PE. Not so much a booth but an actual room (~1500 cuft) with a non treated floor. It's good to around 450 Hz and yes that distortion was gated at 5ms. We usually blend our FR curves for spec sheets around 500-600 Hz. The tweeter for this test was about 61" off the floor on two stands stacked.
    I have attached frd and zma files for anyone who wants to fiddle. Everything is 2.83V/1m, woofer is blended to nearfield at about 720 Hz.
    Epique Woofer.zma
    TL Tweeter.zma
    Woofer 0deg.frd
    Tweeter 0deg.frd
  • jhollander
  • mattp
    Hmm..
    This is promising.
Name:
    A thread to link when people ask "why DIY?"
  • mattp
    The thick plates are the bases and the thinner plates are the tops. These will also be veneered. The PVC will be filled with sand and everything will be held together with 1/4"-20 all thread.
Name:
Name:
Name:
Name:
    And finally...the fun part..
Name:
  • mattp
    More progress. Cabinets are finished after 4 coats. I got one loaded up and ready for measurements, the other will happen soon. I have also started on the stands which should go relatively quick.
Name:
Name:
Name:
Name:
  • mattp
    Originally posted by badman View Post
    Very fine work
    Originally posted by 4thtry View Post
    Beautiful cabinets.
    Originally posted by anunnaki View Post
    Looking great so far! Nice work and can’t wait to see the rest of it come together!
    Thanks guys! They aren't perfect by any means but I am still beyond happy with them.
    Can't wait to see those drivers in the cabinets. Will you be bringing them to any DIY events or at least MWAF next year?
    Not very likely, this whole system is going to be more or less set up permanently in my listening room
    Originally posted by Waboo View Post
    Matt, How did you flush trim the beveled edges? I'm wondering if you used an X-Acto knife or some other type of razor blade.
    I used a normal replaceable razor blade by hand and just took my time, replacing it with a new one after 5-6 edges. This was the best method I could come up with after using two other types of hand/veneer saws. Something else I learned with these is that hand sanding with a sanding block is much nicer in the end than trying to be careful with a sander, which is all I have used in the past.
    Some of the edges could have been cleaner for sure. But it was all a learning process.
  • Waboo
  • a4eaudio
  • anunnaki
  • 4thtry
    Beautiful cabinets.
  • badman
    Very fine work
  • mattp
    One coat down, probably 4 more to go. One looks darker than the other but it is because of the lighting in the room.
    Click image for larger version  Name:	 Views:	2 Size:	145.0 KB ID:	1418651
    Click image for larger version  Name:	 Views:	2 Size:	157.9 KB ID:	1418650
    Click image for larger version  Name:	 Views:	2 Size:	153.9 KB ID:	1418649
  • mattp
    Using a large deep-well socket makes for a decent roller for applying the veneer.
Name:
Name:
Name:
Name:
Name:
