Jeff Bagby's Continuums + Subwoofer
  • Jeff Bagby's Continuums + Subwoofer
    Here's my take on Jeff's design, in curly maple. I messed up a little bit with the spacing between the tweeter and the woofer (measurement error), there should have been a little more space in there - but it seems to have worked out okay.
    The sub is a simple sealed ~12" box with the Wavecor SW223BD02 and Dayton 250w DSP amp. The amp is really nice, made it easy to blend the sub in with the monitors.
    A few more photos.
      Very Very nice
        Beautiful boxes. I really like the contrast between the blond maple boxes and the black drivers, screws and the shadow line on the baffle. Nice job.
          Thanks! I was considering a seamless baffle design with no screws showing, but I'm really happy with how this turned out and glad I went with a more traditional LS3/5a design. I wasn't sure how I would feel about all the screws but now that it's finished I really like them.
            Nicely done!!
            Any construction pics you can share as well?
              Beautiful work! Love the maple figure. How do they sound?
              Carbon13
                Nice job.
                I also like the 250 DSP amp, I have 2 PE 8" kits. The concept really works great for 2.1 sound from a simple stereo source.
                  I did the same thing with mine. Although, I messed up the rear and ended up gluing the backs.
                    Excellent work!
                    Audiophiles listen to the equipment, not the music.
                      Beautiful rendition.
                      Are you high-passing the mains?
                      Really nice setup.
                      Andy
                        The Dayton 250DSP plate amp controls the high and low passes.
                        Dayton Audio SPA250DSP 250W Subwoofer Plate Amplifier with DSP
                          Thanks all! They sound great. I build them for my office, I work from home and usually listen to music 4-5 hours a day so I wanted something that sound great and was easy to listen to. These fit the bill, I can listen to them all day long.
                          I am using the Dayton amp to low and high pass to blend the monitors with the sub. The Continuum's have a bass boost built into the low end which is fine if you don't have a sub but I had to cut it out a bit to keep from having an exaggerated response in the... I think it may have been 80-100hz or so range.
                          Here's some work in progress shots from the build. I'll have to make a few posts to attach them all.
                            Build shots for the sub.
                              Applying the polyurethane finish.
