I have been building open baffle speakers for several years and have been looking to integrate a few new ideas. The Hestia Hybrid uses a single dipole point source combined with a larger monopole up firing driver that is mounted in a tuned and damped slot loaded enclosure. Both drivers operate without a crossover and should not require additional signal processing.
This is intended as an alternative to studio monitors, combining some of the benefits of dipolar / full range loudspeakers with the manageable size and stand-alone characteristics of traditional bookshelf speakers.
Drivers:
Primary – Jordan Eikona II / 100mm aluminum cone (other 3-5” full range drivers may be substituted, and attenuated as needed)
Secondary – Peerless 830869 / 8” Nomex cone
Cabinet:
PE/Denovo Audio Knock-Down MDF 0.67 cu. ft. Speaker Cabinet (modified)
Here’s what I’m hoping to test:
Both drivers operate full range electrically and avoid the monopole to dipole null that would occur around a fixed crossover point if a crossover were used. This helps maintain a symmetrical figure eight pattern associated with classic dipolar dispersion. (Eval 1).
The right angle driver coupling helps reduce frequency modulation distortion (Eval 2) and is a preferred method for combining two full range drivers and minimize lobing.
A tuned and heavily damped slotted enclosure provides low frequency reinforcement that sums constructively with the dipole driver. (Eval 3). The tuning frequency is centered at the -10dB roll off point of the dipole driver for cohesive (non- destructive) low frequency support.
An adjustable driver mount is used to better align the acoustic centers of both drivers and optimize phase coherence (Eval 4) at the listening position.
The adjustable dipole mount provides micro toe adjustments as well as a way to help manage floor and ceiling reflections (Eval 5).
