my favorite 2.1 subwoofer / satellite system yet!
  • my favorite 2.1 subwoofer / satellite system yet!
    I've built many 2.1 subwoofer / satellite speaker systems over the past few years. It's decor friendly since the satellites are small and the subwoofer can be tucked away somewhere unobtrusive.
    This system has satellites which consist of the Tang Band W3-1364SA bamboo cone drivers and the Peerless dual ring radiator tweeters XT25SC90-04 in sealed enclosures. Crossover is a 2nd order on the woofer and 3rd order on the tweeter.
    The subwoofer is a slot port design by 123Toid Altoid using the Tang Band W6-1139 woofer. Enclosures are MDF with veneer and the baffles are 3/4" solid walnut. Finish is Arm-R-seal gloss
Name:	high end 2.1 speakers.jpg
    What did you end up powering the system with?
    They look great. You are on a roll with all the projects you've completed recently.
    My Builds - Vigor (Nola Brio Knockoff) - Overnight Sensations w/ Voxel - Speedsters in surplus boxes - Zaph B3N's in bamboo - Classix II in BR-1 cabinets - Dual TPA3116 D2 amp in an old music box - Mariposas
      Very nice build ceiol. I'd be curious about a ported version of those satellites.
      Last edited by Jake; 07-03-2020, 10:11 PM. Reason: On second thought xmax is only 0.5mm
      • ceiol
        ceiol commented
        Editing a comment
        you could, but those mids have a 0.5 mm Xmax only. Ported modeling has them bottoming out quickly.
        sealed and stuffed looked much better on the models
      Very attractive looking set up.
      I have the same amp, I really like it. What do you think of it as it applies to the 6.5" Tang Band sub?
      TomZ
      • ceiol
        ceiol commented
        Editing a comment
        I do mostly low level listening, so that amplifier is fine.
      Very nice set. Would you please mind sharing your crossover diagram and satellite enclosure dimensions. Thanks very much in advance.
        Great looking set!
        Could i get the sub build specs? I have a couple of those subs and would like to build something similar.
        I built a RJB Cerberus, but it chuffs too easily, so looking for a build with better port configuration.
        Thanks, Andy.
        • ceiol
          ceiol commented
          Editing a comment
          it's about 0.4 cubic feet and the port is 1/2" tall by 7.5" wide, total port length of 17" or so. tuning is 37 Hz
          the Cerberus has a 1.5" diameter port = area of 1.76 square inches
          this slot port has an area of 3.75 sq inches = the area of a 2.2" diameter port
        Awesome work! They look phenomenal. Is it your own crossover or a published design?
