Amp Camp amps
Now this has my interest...I was wondering if such a kit existed just recently! I hope you plan on documenting your build, I would love to follow it and see what all is involved in an amp build.
Unless you have a pair and bridge them, yes, they are higher HD units- but pleasing 2nd order.
Try Classdaudiodotcom for high power low distortion amp kits. Or check with forum member SilverD, he has built several amps using modern components.These are maybe 8 watts of class A power with, as Wolf says, pleasing distortion. Audio Science Review kicked them to the curb, others love them. Build two so you have enough power. I will report when done. Reams of info on the internet.
I'm also interested in the build and look forward to your opinion.
Assembled one chassis. Very good fit, some of the tapped holes need cleaned out. Everything screws to the heat sink sides. This chassis is available from many sources. Most have stick on feet. This seller includes bolt on feet, no holes or hardware for that. I may just epoxy them.
The DIYaudio sourced chassis mounts a large round on/off switch on the front panel. I will probably move that to the rear, I do not have a good way to make a large clean hole in the 5/16" thick front panel. I will drill two small holes for two LEDs
So I have to drill and tap the heat sinks for the PCB and solid state devices, since I didn't buy the pricey diyaudio chassis. The heat sink material is surprisingly tough. I was expecting dead soft aluminum. A solid state device hangs off both ends of the PCB, so 8 more holes. The heat sink is just wide enough for the PCB. There is another larger chassis available, but it has a hole in the back panel for an IEC AC jack, these are brick powered.
- 1 like
Looking good so far.
Nice enclosure. Are you just adding two D/C jacks for those power bricks? I'll be very interested on your listening impressions.
I'm making a pair of the amps as numerous comments on the web recommend bridged operation for any meaningful output. The original project was a one day "amp camp" for people to build their own modest amp. That led to the power brick to avoid house current for really rank beginners who never held a soldering iron before.
I have shown a complete lack of critical listening skills, so I'll say something about the sound. Don't expect John Atkinson.
No Nate, the Italian DIYaudio custom cases look similar, but are not the same. The Chinese WA92 spec case has 6 pieces. The front, back, top and bottom screw directly to the heatsink sides. The Italian case has rails to which the surfaces attach. DIYaudio offers a really nice case, but it's too much for me to spend on a little fleawatt fun project.
