Im feeling like the bottom might be the achilles heel of the design.
Choti Surrounds with 3D Printed/Sand-filled enclosures
You did so well with the bracing and deadening of all other sides, then the bottom is a thin flat sheet of plastic (as far as I can tell). Seems like that would need some extra deadening to keep it from acting like a PR at it's resonant frequencies. Maybe pinewood derby car weight plates or shaped steel plates attached with 3m double sided tape. Something like that would add a lot of damped mass... hopefully without awkwardly sticking out the bottom.
Originally posted by DrewsBrews View PostYou did so well with the bracing and deadening of all other sides, then the bottom is a thin flat sheet of plastic (as far as I can tell). Seems like that would need some extra deadening to keep it from acting like a PR at it's resonant frequencies. Maybe pinewood derby car weight plates or shaped steel plates attached with 3m double sided tape. Something like that would add a lot of damped mass... hopefully without awkwardly sticking out the bottom.Form does not follow function
Form is simultaneous to function
