3.1 - Overnight Sensations + Cerberus sub
Re: 3.1 - Overnight Sensations + Cerberus sub
Originally posted by djg View PostI did a 5.1 with that sub and three OS, later updated with an MTM for the center. Recipient was very happy, now wants more bass, he's a kid. Paul put a pic of the original system on his site.
I've used the Tang 6.5" sub for 3 different sub designs so far, and it is a good performer.
Your project sounds solid. Please post up some pics as you go, we'd love to see them!
TomZZarbo Audio Projects Youtube Channel: https://www.youtube.com/channel/UCEZ...aFQSTl6NdOwgxQ * 320-641 Amp Review Youtube: https://youtu.be/ugjfcI5p6m0 *Veneering curves, seams, using heat-lock iron on method *Trimming veneer & tips *Curved Sides glue-up video
Finalized the dimensions:
single ONS (x2) = 6-3/4" x 8-5/8" x 8-3/16" Deep using 5/8" MDF
MTM ONS (x1) = 6-3/4" x 16-1/8" x 8-3/16" Deep using 5/8" MDF
this should minimize table saw set-ups as I only need to rip 6-3/4" and 8-3/16" strips.
I laid them out with the speakers on cardboard, the dimensions are good and within appealing proportions.
good news, looks like it should be warm enough to possibly do my big board cutting Friday night. I dream of cutting circles but reality is that's probably a dream
Here is my mock cross overs. MTM on the left and the single on the right. I made them narrow enough to fit through the B4N speaker hole. What are some tips for soldering cap-to-cap, cap-to-inductor ... etc? I'm assuming you need to scuff off the varnish then just go for it? I'm not a noobe at soldering, just haven't done a cross over. Thanks
[IMG][/IMG]
Originally posted by beemain View PostWhat are some tips for soldering cap-to-cap, cap-to-inductor ... etc? I'm assuming you need to scuff off the varnish then just go for it? I'm not a noobe at soldering, just haven't done a cross over. ThanksIsn't it about time we started answering rhetorical questions?
Twitter: @undefinition1
Thanks
I have most of the wood cut too. Just need to add dado's (yes, I like the hard way) to the edges and of course router the holes. I'll be flush mounting everything. Of course with a 2 and 3 yo there isn't much time for me, haha. Hope to have the wood work at least dado'ed (is that a word) so I can start making router dust over the week.
Right now my thoughts on finishing are to skim coat with a light weight body filler, block, prime, prime, prime, light coat of "hammered steel paint" for a bit of texture and finish with satin black or black/brown. No texture on the front face. Time's a ticking and I need these done.
Phew, got the dado's all cut and ... everything fits! Nice to see some dry fit boxes on the saw. Get out the Jasper jig, time to cut some holes. I'll post my cut sheets tomorrow for anyone that's interested (I used 5/8")
Here are the cut sheets for my version of the ONS. This gives you a left and right and an MTM center.
[IMG][/IMG]
[IMG][/IMG]
I like to add an 1/8" all around on the pieces that have outside edges, such as all the front, and the tops and bottoms of the side pieces. This way, once assembled you run it through the router table with a trim bit and all the corners (edges) are perfectly tight and matching. The dimensions above do not allow for this. If desired add 1/4 when cutting and make your dado's 1/8" deeper, only on the dimensions that have dado's, none dado'ed edges are cut exact fit.
Well, got the 4" speaker holes cut and practiced the tweeter holes. They won't take long at all using the drill press. Here are some pictures:
I used a Jasper jig. To make it safe and avoid loosing the center pin when I get to the bottom of the hole I like to screw from the back side the piece getting the hole to another piece of scrap. In this case plywood. The plywood is nice an long so I can clamp it to the work bench and not hit the clamps with the Jasper jig. When you get through your good piece the center pin remains intact and no danger of is skating and ruining your work.
Here I have the flush hole done, ready to cut the speaker hole
[IMG][/IMG]
Hole cut, center pin still intact
[IMG][/IMG]
core removed (note, I have the Left and Right screwed to the same piece of scrap wood)
[IMG][/IMG]
And the result, a nice flush mounted speaker (this one is inserted into the MTM face plate)
[IMG][/IMG]
Note: no front port on the MTM, it just wouldn't fit. If I had the space I'd make it 2" wider and front ports would fit. I could had front ported the L&R but I thought it looked silly with the port right beside the tweeter.Last edited by beemain; 01-25-2011, 04:03 PM.
You do nice work. I like the tip about anchoring the center pin location from behind. Is that whiteboard you're using for your crossover networks?
All that talk about "Day of the Tentacle" sent me scurrying to Wikipedia. Us, uh, more mature types, have to do a little research now and then. So it's a video game...
I'll be watching your build with interest. I have the components for two (sets) of Paul's Overnight Sensations.Tritrix HT:http://techtalk.parts-express.com/sh...d.php?t=222519
Dayton 12" Subwoofer: http://techtalk.parts-express.com/sh...d.php?t=222930
Overnight Sensations: http://techtalk.parts-express.com/sh...d.php?t=223751
Cerberus sub: http://techtalk.parts-express.com/sh...hlight=cerebus
Duellatis: http://techtalk.parts-express.com/sh...d.php?t=224943
NTN's: http://techtalk.parts-express.com/sh...d.php?t=227902
