An off-kilter 3-way: The Ziggurats
  • An off-kilter 3-way: The Ziggurats
    This is hopefully the culmination of a long drawn out attempt to make good use of a pair of HiVi F8 woofers. At first they were part of an 8" 2-way design. But after hearing another F8 based 2-way at DIY Iowa in 2010, the thought occurred to me that the F8 was ballsy enough to carry the bottom of a rockin' 3-way. This is how a long journey has finally wound up.
    The drivers:
    HiVi F8 woofer, RS52AN-8 2-inch dome mid, and the RS28A-4 aluminum dome tweeter.
    The goals:
    1) To utilize the HiVi F8 as the basis of a 3-way.
    2) To give the F8 enough volume to produce the bass exhibited in Robert's "Throwbacks", yet disguise that volume in a unique design that would blend in with it's surroundings (flanking a low TV stand).
    The cabinet is somewhat like a tower split diagonally down it's length. Thrown alongside a tv stand you get what looks like a ziggurat, hence the name. Outside dimensions are approximately 13" wide at the base, 13 inches deep and nearly 31" tall. The net volume is around 30 liters. These are ported out the back with a 3" flared port with tuning of approximately 40 Hz.
    These are in the tweak and evaluate stage. I have them placed on 10" stands right alongside a 24" tall TV stand holding a 55" LED TV. I like the bass. I know some folks aren't fans of the RS52. In the workouts I've given them so far the mid hasn't been the least bit irritating. So far, so good, but I don't know if I'd call them finished yet. Also, the jury is still out on whether the design meets SAF requirements. Grilling that bright yellow F8 may still be needed.
    Re: An off-kilter 3-way: The Ziggurats
    I like it. I too, have put my F8 in a 3-way paired with a peerless 5 1/4" paper midwoofer and vifa dq25. Gifted it to my brother-in-law for Christmas and he is loving it. The bass is capable of rattling his walls. We tried, if only for a short time.
      I've seen the Ziggurat temple near Talil (Adder) in Iraq I couldn't go in it though, they weren't doing tours anymore, and I had like 4 hours to hit the road after I woke up :rolleyes:
      रेतुर्न तो थे स्रोत
      return to the source
      leviathan system thread
      deadhorse thread
      shockwave build thread
      instagram :: greywarden_13
        Turn, you'd make AndyG proud!
        Some of my audio projects:http://www.flickr.com/photos/8626051@N04/sets/
          I like these. Are they all black? I think I see veneer in some of the pictures.
            To cool man! I like out side the box thinking, you've executed that design quite well.
            A mains
            The Ventures
            Open Invit8tions
            RSR
            Sound Troopers
            Acorns
            442
            DGBG's
            The Monuments
              Just what I was thinking...
              Nicely done. Hope that RS52 sounds alright to you.
                To be honest, not my cup o' tea, but a very well executed concept and is good to see something other than another rectangle. Well done, and that woofer looks striking against that black.
                  Damn fine work! I feel like it's been years since we've seen some crazy cabinets like that. Great execution!
                  I always liked Andy G's adage: "Cutting crooked's real easy. It's cutting straight that's hard."
                  Twitter: @undefinition1
                    Cool!
                    Reminds me of a couple builds I did a long time ago.
                      I've got a couple more shots. One shows the veneer. (Theres also some tape residue around the baffle that has since been cleaned up.) It is a generic open grained oak that I'm not real fond of. Sort of stuck with it now, unless I take drastic measures. It does make a bold statement.
                      The other shot shows the set-up where the speakers now reside. Keep in mind the lens is making things look round at the edges. I'm not using the center channel with them. I'm hoping these will eventually move to a different room with a smaller TV and a bit narrower stand, and no center or sub.
                        I like them! Nice to see something different. I don't think I will ever build another all 90 degree speaker. I think they would look good with a full grille, then the oak sides would be more of draw to the eye. A solid stand would look better too I think, plus that open box area underneath may cause a resonance. Good job!
                          Pretty nifty Turn2. Looking pretty darn nice, despite your reservations on the veneer.
                          How do they sound? What did you wind up with for XOs?
                            All they need is some tie dyed grilles and they'd be totally groovy man! All kidding aside, they look great, nice job.
                            My modest builds:
                            Armadillo TM, A.K.A. Lil' Dillo
                            Tarkus/Armadillo build #2
                            Armadillo Center Channel
                            Au-Rock-O Sub
                            Tarkus
                            Staining MDF tutorial
                              Thanks, Pete. I'm pretty happy with the sound so far. With a 3-day weekend coming up I should get a chance for more long listening. With the goofy baffle dimensions the PCD work was a real learning experience. Getting that RS52 under control isn't a simple matter either.
                              BTW, the stands are just some cheap pine steps from a hobby store painted black. At one time I considered adding stubby legs to the speaker. Once I figure out the listening height I prefer I'll do something more permanent.
