The Armadillo Center Channel
  • The Armadillo Center Channel
    This is a collaborative project between Mark65 and I, with Mark doing the crossover simulation and box modeling, and myself doing the actual build and the 3d drawings. This project came to be, because I was looking for a center channel design that could keep up with my main speakers (Paul Carmody's "Tarkus") . We decided to use drivers from the same manufactures as the Tarkus design, to keep a good visual and sonic match. However, none of these are actually the same drivers.
    The woofer: Peerless SDS-160F25PR01-08 6.5" was chosen because of it's strong bass performance in a sealed enclosure, and it's near identical aesthetics to the Peerless 830657 6.5" used as a mid in the Tarkus design. As an added bonus, it's also $6 cheaper than the 830657.
    The mid: Peerless 830656 5-1/4" Paper Cone SDS Woofer was chosen because of it's extended response into the upper midrange, descent spl, and again similar aesthetics and construction to the other Peerless drivers being used. We also needed it to fit on our baffle with a tweeter above it, due to the height restriction of my intended placement, inside my AV cabinet. The truncated frame definitely helps.
    The tweeter: Vifa XT25SC90-04 1" Dual Ring Radiator was chosen primarily because of it's small faceplate, and excellent off axis response. Mark has used it before and agrees it was an excellent choice.
Name:	CC Dimensions.jpg
ID:	1187140Click image for larger version
    The cabinet: Pretty simple stuff, sealed cabinet 25" wide, 8.5" tall, and 14" deep with a separate 2.5 liter chamber for the mid. All .75" material. Woofers and mid are surface mounted, the tweeter is flush mounted. It's a tight fit, the edge of the mid is right at the edge of the tweeter recess, some careful measuring was required before cutting the driver holes into the baffle, but if a hack like me can pull it off, it is do-able.
ID:	1182005Click image for larger version
    The crossover: This is Marks territory here, one thing I can say is that the response is indeed very flat as the sim suggests. The only change to the crossover that was made, after a bit of listening, is a bit of additional padding on the tweeter (the 3.3 ohm series resistor). I bumped it up to 4.7 as it was just a tad hot in the top end. Mark suggested ordering a few different values to play with, adjust it to your taste, and I will suggest the same. I would think between 3-6 ohms would be good.
    Last edited by bolland83; 12-06-2013, 10:21 PM. Reason: Updated dimensions and added interior detail photo.
    My modest builds:
    Armadillo TM, A.K.A. Lil' Dillo
    Tarkus/Armadillo build #2
    Au-Rock-O Sub
    Tarkus
    Staining MDF tutorial
    Re: The Armadillo Center Channel
    The finished build:
ID:	1143763Click image for larger version
ID:	1143764Click image for larger version
ID:	1143765Click image for larger version
ID:	1143766Click image for larger version
    Conclusions: I think Mark hit the nail on the head with this one, action scenes with sounds panning from left to right are seamless! Dialogue is clean and clear, but not overpowering, it blends in very well with my mains. Off axis response is great, there's certainly no dead spots in my living room. It even sounds great with music, the extended stereo modes on my receiver are actually enjoyable now, vs. my old commercial speakers where it was like "eww, that's nasty sounding". All in all, I'd say it's a great success :D
    My modest builds:
    Au-Rock-O Sub
    Tarkus
      The bill of materials, as built:
ID:	1143771Click image for larger version
      The crossover layout:
ID:	1154249Click image for larger version
ID:	1154247Click image for larger version
      My modest builds:
      Au-Rock-O Sub
      Tarkus
        mark is my hero. ok, so are you. great project you two!!
          That's fricken SWEEEEEEEEET, but keep the kitties away. I think I see a cat-scratching post back there??
          Bryan K.
          Midwest Audio Club
          Speedster | Sub Attach | The Wildeman | Sean's NLA Towers | COGAR, COUGAR II and COGAR JR | Triton | Lithium | J-Boom | Trym MLTL | Docere MLTL
            That looks awesome man
            रेतुर्न तो थे स्रोत
            return to the source
            leviathan system thread
            deadhorse thread
            shockwave build thread
            instagram :: greywarden_13
              that finish is just unbelievable! AMAZING
              My Build Blog: LHark Audio
                Wow, you two. Great job! Now we finally have an answer to the much-asked question about "is there a matching center for the Tarkus?"
                Twitter: @undefinition1
                  Beautiful job with the center and the finish it looks great. I love the sunburst with the matching TV stand and Tarkus mains.
                  "I like Brewski's threads, they always end up being hybrid beer/speaker threads based on the name of his newest creation." - Greywarden
                  Breakfast Stout - HiVi RT2 II/Aurasound NS6
                  Imperial Russian Stout - Vifa DX25/Fountek FW146/(2) Fountek FW168s - Built by Fastbike
                  Ruination 2.5 way - Vifa DX25/Fountek FW168
                  Levitation TM
                  - Vifa BC25SG15/Fountek FW168
                    I think I was the first one to ask that question, I'm glad you approve! I'm also hoping this will prompt more people to show Tarkus some love, they make great HT speakers :D
                    My modest builds:
                    Au-Rock-O Sub
                    Tarkus
                      Paul, we appreciate the validation! It does what we were shooting for, and I don't think we could be happier with it.
                      Gaelen did a STELLAR job of building this, as is his MO, and I'd be very remiss if I didn't point out the fact that he has come up with a revolutionary finishing technique. Quite simply, I've never seen the like of it, anywhere. It's easy, cheap, and stunning. IMHO, he's made a contribution to this hobby that I'll never be able to match: The Great Thing That No One Has Done Before.
                      I humbly bow to the genius....
                      Mark
                      You go your way, I'll go mine. I don't care if we get there on time.
                      ~Pink Floyd
                        Mark
                        ... says the guy who designed a 3 way crossover that will work with a CC AND a tower!
                        My modest builds:
                        Au-Rock-O Sub
                        Tarkus
                          Once again, hit this out of the park. That finish technique continues to be amazing.
                            Originally posted by bolland83 View Post
                            [ATTACH=CONFIG]29058[/ATTACH]
                            Guys,
                            A question on the notation you used for the mid section of the XO - it is marked as getting the negative signal on the far left, but still going to ground. I'm guessing you're indicating that the mid's polarity is simply flipped. Can you confirm?
                            Thanks,
                            Colin
                              Very nice, guys. I now expect a TM and/or bipolar surround and a matching LR tower to be completed within the week :D
