The Neutrino - A High-Output Mini-Monitor
  • The Neutrino - A High-Output Mini-Monitor
    In my newly-minted position at Parts Express, I’ll continue to have opportunities to design my own loudspeaker projects on the side, but I’ll want to make sure they can be published as Project Showcase projects, so they’ll need to be designed exclusively using products from Parts Express. However, this project doesn’t fit that mold, so I’m publishing it here instead, because frankly the results have been too good not to share with the community.
    Introduction
    Let me tantalize you, first of all, by saying that what these speakers do should not be possible. You don’t get this performance from a speaker this small, and you don’t even necessarily get this performance from a speaker with a midwoofer two sizes larger.
    I had the idea for the Neutrinos in the spring of 2010, when I lived in a hotel room in Connecticut for two months while working on-site for a major aircraft manufacturer. I had my previous Whetstones design in the room with me, and they did an excellent job, but I began to wonder what the ultimate speaker for this application might be, in case I ever found myself in the same situation again. I surveyed the market, and was impressed by the small speakers offered by Amphion, which used a midwoofer and waveguide-loaded tweeter from SEAS, in a stylish white cabinet with rounded corners, but I thought it might be possible to improve on the overall performance for the application. Since the Amphion Ion had been my inspiration, I decided to pick a name from particle physics, the Neutrino. The name accurately reflects the design goal of creating a neutral-sounding mini-monitor with big performance from a very small enclosure.
    Driver Selection
    The key to the performance I sought from a small speaker was the Tang Band W4-1720, which if you haven’t yet heard, is the ultimate small midbass driver. Everything that has been said about this driver is true; its ability to play loud and low without distortion is legendary, and while it isn’t the very final word in resolution, it’s darn near it. The key to this performance is a motor structure that uses a long-excursion ‘underhung’ topology, and a huge mass of steel and ferrite that barely fits through the mounting hole for the driver itself.
    I decided to look around for a tweeter with an underhung motor structure to pair with the W4-1720, in order to stick with the overall theme, and I arrived at the SEAS 22TAF/G tweeter for that purpose. It has a 20mm-diameter aluminum/magnesium alloy dome diaphragm, suspended with an oversized surround made from a treated fabric material that SEAS calles “Sonomex”, which makes up almost twice as much of the driver’s radiating surface as the dome itself does, making this tweeter effectively a hybrid of a fabric dome tweeter and a small-diameter metal dome, with the metal dome being coupled to the 20mm voice coil. Even though the voice coil is small, the tweeter boasts long-term power handling of 80 watts, thanks to the use of ferrofluid, and a low free-air resonance of 1100 Hz.
    Enclosure DesignCrossover Design
    Best Regards,
    Rory Buszka
    Product Manager, Dayton Audio
    The best way to predict the future is to create it.
    Re: The Neutrino - A High-Output Mini-Monitor
    Listening Impressions & Conclusion
    After sorting out the voicing issue described above, the Neutrinos have achieved their goal of being a neutral source that achieves high output levels from a small enclosure. While they aren’t very efficient at about 80 dB 1W/1m (and some would say they are very in-efficient), they play extremely loud when fed with plenty of solid-state juice. I use my APA150 to drive them, and can achieve lease-breaking levels in my room. I think a major contributor to the Neutrinos’ high output is that their enclosure is over-damped and tuned almost exactly to the driver’s Fs, rather than below it as other designs that use this woofer have been. As a result, the mid-woofers remain well within their linear excursion range at high power. I have not been able to detect any port noise, even when playing sine signals at the tuning frequency, though I did have to resolve a couple of air leaks around the drivers. Also, the fairly high crossover frequency used for the tweeters allow them to loaf along within their own linear region, so their output is smooth and non-fatiguing. Imaging is very good, as is to be expected from small monitors, but the soundstage width and depth are startling. This design nicely straddles the line between aggressive and laid-back tonality, and is very listenable for long periods.
    Parts Express discontinued the W4-1720 driver along with the rest of the Tang Band underhung drivers in early 2012, but thanks to popular request, they have reinstated the W4-1720 model. That means you can still build your very own pair of Neutrinos if you desire. I think this is one of the very best small speakers I have heard, and I think you’ll find them very worth your while.
    Crossover Schematic
    Crossover Simulation
    Measurements
    OmniMic response plot:
    This measurement was taken in my bedroom, on a 24" speaker stand, with the OmniMic V2 microphone 1 meter away, and other reflective objects/surfaces at least 1 m away also. Blended windowing was used to get a picture of the low-frequency behavior, but there were some floor- and wall-related artifacts that led to a couple dips in the low end. Actual performance is -3 dB at about 65 Hz, and -10 dB at 40 Hz, but when placed closer to a wall they develop a completely different low-end character that is smooth and extended to at least 40 Hz before rolling off. This means they can be used on a typical desktop (against a wall) without a subwoofer and still provide captivating low-end response. They really are sensational when used in this way.
    Downloads
    Cabinet Plans - Zip file with cabinet Plans in PDF and DXF format
    Simulation Data - Zip file with Neutrino simulation data (generated by Bagby tools) and Bagby PCD session file
    OmniMic Screen Grab - A view of the OmniMic measurement screen during measurement, for FR and impulse data
    Last edited by RoryB@daytonaudio.com; 10-07-2012, 11:57 PM. Reason: Added measurements and explanation
    Best Regards,
    Rory Buszka
      Rory,
      Very nice project, impressive cabinets and very good writeup!
      I am very interested in the tuning approach you used, which relies on the drivers strengths and not using the cabinet to get sumtin' fo' nuttin' which as you expained equates to keeping the woofer happy at elevated volumes. I like designs that are limited by your volume knob, not by excursion.... Well Done!!!
        Very nice.
          [QUOTE=RoryB@daytonaudio.com;1858236] For the Neutrinos, I used a room-aware overdamped vented box alignment tuned to 58 Hz (very close to the W4-1720’s Fs) to minimize excursion and assure linear performance even when placed in a typical room. I performed this room-aware enclosure tuning by first simulating the in-room response of the loudspeaker using Jeff Bagby’s Baffle Diffraction and Boundary Simulator tool, where I entered a worst-case room size of 16 feet by 20 feet, with the speakers located four feet from the back wall and seven feet from the side walls. Then I saved the resulting room and baffle curve as a FRD file and loaded it into Bagby’s Box Designer tool, and optimized the vented box alignment for maximally-flat performance in the given room. This allowed me to keep the enclosure size to a minimum for the given tuning, but you can also use this technique to optimize bass extension instead.
          /QUOTE]
          Rory - thanks for the great writeup. I'm always the guy with the dumb questions.
          Can you expand on this section and process a bit more? Some graph shots and options along the way
          might be helpful.
          Tangband W6-sub
            Glad to see this project finally come together, Rory. I look forward to hearing them sometime soon.
            Twitter: @undefinition1
              I'm definitely using that shape for my Deadhorse project, which reminds me, is at the 2-year mark this week ;(
              Great write-up. Did you get the crossover worked out properly?
              रेतुर्न तो थे स्रोत
              return to the source
              leviathan system thread
              deadhorse thread
              shockwave build thread
              instagram :: greywarden_13
                Update:
                Crossover schematic, enclosure drawings, and PCD simulation data uploaded.
                (Yes, Grey, I sure did.)
                Best Regards,
                Rory Buszka
                  thats nice rory. perhaps pe will let you come to grinnel with them when you bring the door prizes.
                    Updated with measurements.
                    Best Regards,
                    Rory Buszka
                      Rory, is the crossover schematic posted here the one just heard at InDIYana 2013, or has it been tweaked further?
                      Pleasure to meet you over lunch in Ft. Wayne. Sorry to hear you weren't feeling completely well.
                      David S
                        The above schematic is fully up to date. There should be a 4-ohm resistor before the high pass network, and a 4.5-ohm resistor after.
                        Best Regards,
                        Rory Buszka
                          I'm curious about sound levels. You said, "... about 80 dB 1W/1m..." and "...they play extremely loud...". Do you mean for near-field applications they play good solid sound? They are really pretty and look like they belong right at head level with a couple of monitors and maybe a keyboard + DAW in between. OTOH, I don't see how a ~30 watt driver starting at 80 dB is going fill a big space. The APA150 looks to be a good match - it will run out of steam right about the same time as the TB.
                          Any consistency issues between the two TB's? I've not had great luck getting matched pairs.
                            They filled the conference room rather loudly at InDIYana, so I can vouch for that.
                              The W4-1720 has an xmax of 5mm. In Rory's box, simulation says they reach xmax w/ 30 watts. At the point they are making 101dB. FWIW, modeled sensitivity is 89.1 / 2.83 volts, 85.9 / 1w
