Lithium
  • Lithium
    Lithium is a small monitor that doesn't have any idea how small it is.
    Drivers:
    Dayton ND-105-4
    Vifa BC25SC06-04
    Crossover:
    LR4 acoustic 2.4 kHz.
    Dimensions:
    9" tall, 6" wide, 8" deep (same as Overnight Sensations).
    Price:
    Drivers + Crossover = $170 as of 10/15/2012
    Design goals:
    Mike Zisserson's New Horizons and Chris Roemer's Nano Neos have been very well-regarded designs. I liked the potential of the ND-105, but wanted something smaller that could go easily on a wall, shelf, or desktop. Since the small Dayton neo tweeters have increased in price, I thought there might be a better value out there. The Vifa BC25SC06-04 has slight horn loading, that aligns the acoustic center with the ND-105. Lithium was designed to give satisfying musical response by itself in tight quarters, or work well as a home theater satellite - enabling a low enough crossover to minimize subwoofer localization in small to medium rooms.
    Cabinet:
    When DIY Sound Group first introduced the Overnight Sensation flat pack, the woofer cutout for the HiVi B4n was not countersunk. I noticed that the ND-105 would drop in perfectly, so I had my cabinets. The cabinet walls are 1/2" baltic birch. The PE 1" by 4" flared port tunes the cabinet to 47 Hz. The side and back walls are lined with R9 Ultra Touch denim fiber insulation available by mail order from Home Depot. I finished with Minwax cherry gel stain and several coats of wipe-on poly.
    Crossover:
    I wanted to get the crossover frequency low enough that there wouldn't be any off-axis beaming from the woofer or issues with aluminum cone breakup modes, but high enough that the tweeter wouldn't be stressed. I settled on a 2.5 kHz fourth order Linkwitz Riley acoustic target. In order to get that, I had to go 4th order electrical on the ND-105. The very efficient Vifa tweeter took a lot of padding to get down to the level of the ND-105. I estimate about 5 dB of baffle step compensation, which gives a relatively full sound for most placements.
    Measurements:
    The on axis response is flat within +/- 2 dB from the lower limit of accurate gated measurements in my room (200-300 Hz) to 18.5 kHz. The reverse null indicates a crossover point of 2.4 kHz. Off axis, there are no significant flares or other issues. The impedance plot has a minimum of just over 4 ohms at 180 Hz. It doesn't stay below 5 ohms for long, so by commercial standards it would be a 6 ohm design. The saddle between the two low frequency points shows the port tuning frequency of 47 Hz.
    Listening Impressions:
    I won't offer any yet. These will be coming to DIY Iowa 2012 in Grinnell this weekend - so we should have some feedback soon.
    Sehlin Sound Solutions
    Re: Lithium
    Here is the impedance plot...
      Re: Lithium
      Love that little Vifa tweeter. Amazing you can get such solid bass in a box that small.
      Tangband W6-sub
        Re: Lithium
        Gee, what should a guy do if he has almost all the parts including the OS DIY cabs. . . . . ? :D
          Re: Lithium
          Nice! I wish I could hear them, but I don't think I can make it to Iowa this year.
          I'm very curious how the ND105-4 fares in that box. The filter looks very interesting as well. I think I might have to try it to see how you did it!
          Twitter: @undefinition1
            Re: Lithium
            It really is an impressive driver. F3 models at about 51 Hz and I believe it from listening.
            I'd say you can't go wrong - but let's see how it fares in that big auditorium in Grinnell.
            If I ever wind up in your neighborhood or vice versa, we should get a listening session together. The main issue with the filter is that the ND-105 just seems to need a higher order filter to really convince it to do what you want rather than the other way around. The standard notch and tank filters leave too much residual HF content - as the ND-105 tries to be a full-range driver. The tweeter just needs a lot of padding.
              Re: Lithium
              The tiny monitor sounded very good in the large hall in Iowa an was the smallest of the lot there!
                Re: Lithium
                OK Scott, here's your critique: The Lithium's rocked. They're as good as can be. Enuf said!
                Alright, really there's not much you could possibly do to improve them. As I mentioned to you yesterday, I see some of the stuff that you put together and wonder what you're thinking, then hear what you've done and shake my head in amazement.
                  Re: Lithium
                  If anyone has these parts "lying around" and you DON'T build this, it will be YOUR loss.
                  I always thought the ND105 required a larger volume cabinet if you wanted to take full advantage of its crazy XMAS. WRONG. Scott proved what can be done with this driver in a minimalist enclosure, and his tweeter choice and crossover design make it a real winner.
                  Bryan K.
                  Midwest Audio Club
                  Speedster | Sub Attaché | The Wildeman | Sean's NLA Towers | COÜGAR, COUGAR II and COÜGAR JR | Triton | Lithium | J-Boom | Trym MLTL | Docere MLTL
                    Re: Lithium
                    What gauge is used in the inductors? These look interesting for a bedroom system.
                    My Statement monitors
                    My Piccolatas
                    My LM3886 amp
                      Re: Lithium
                      The 2 mH inductor is 18 Ga. laminate core. The 0.47 mH is 18 Ga. air core. The 0.70 mH is 20 Ga. air core. I think the 0.70 is the only one that will be really sensitive to changes - if you had something like a 15 Ga. air core or 18 Ga. laminate core, you might have to add 1/2 ohm of series resistance with it to avoid having a little peak where you don't want it.
                        Re: Lithium
                        OK, thanks, that drops about $12 vs having all air core 18 Ga.
                        what caps did you use?
                        My Piccolatas
                        My LM3886 amp
                          Re: Lithium
                          I just went with Dayton polypropylene caps (5% tolerance, 250V). Any entry-level poly caps should give good results. I think you could get away with non-polar electrolytic (NPE) for the 30 uF if you prefer - it would give a little more breathing room for fitting the crossover in the cabinet.
                          I can tell you from experience that anything fancier or significantly higher voltage rating than the Dayton's may give you an issue with fitting the crossover in the cabinet.
                            Re: Lithium
                            Thanks again. Now I need to finish my statement center so the wife does not complain.
                            My Piccolatas
                            My LM3886 amp
                              Re: Lithium
                              Scott, do you think there will be any significant difference between the Ultra Touch Denim and PE's Sonic Barrier ??
                              How thick is the Denim stuff? I have 1" Sonic Barrier on hand -- that's why I'm asking.
                              Somebody's gonna get these for Christmas from Santa
                              Bryan K.
                              Midwest Audio Club
