2nd Annual Stock-toberfest
2nd Annual Stock-toberfest starts October 17th! Time to stock-up on great products at great prices! Click the Parts Express Logo at the top left of this page.
See more
See less
Wolf's PC, Sprite, and Voxel Subwoofer 2.1's in Walnut
  • #76
    Re: Wolf's PC, Sprite, and Voxel Subwoofer 2.1's in Walnut
    I can see the light at the end of the trunnel for this project. Mt bluetooth recievers and terminal cups arrived and I made a little more headway on the Voxels. If I had double the clamps I own I would be further along!
    My set up for laying out the curves I cut at the bottom of the enclosures.
    For the sake of uniformity, I used double sided tape along with masking tape to pair up the front and rear baffles for the bandsaw cut and spindle sander work.
    Glueing up.
    The port tube.
    Woofer holes are cut and chamfered.
    Thanks,
    Jeff
    Projects:
    "Overnight Sensations" Build Thread
    Wolf's "PC", plus Paul Carmody's - "Sprites", and "Voxel" subwoofer 2.1 micro systems - Build Thread
    • #77
      These look so good. I love the craftsmanship.
      DIY Jukebox Kits
      Curvy Retro Bluetooth Boombox
      • #78
        Excellent attention to detail. Can't wait to see finished product.
        For the glue ups, do you just use a wet rag to wipe off the glue while it's still wet? Or do you chip it off after it dries?
        • #79
          I'm a big fan of Danish Oil and walnut, great combo. Nice work.
          • #80
            All I can say is omg...I would just sit around and stare at em,,wow
            • #81
              This project is completed. Bothe combos with either pc and voxel or sprite and voxel sound great. The voxel and sprite combo can really pump out the bass.
              Detail of PC flush mount rear panel.
              Wolf's "PC"
              Paul Carmody "Sprite"
              Sprite - countersunk port tube.
              Voxel Subwoofer
              Thanks,
              Jeff
              Projects:
              • #82
                Ridiculously good work man. Two thumbs waaayyy up !
                • #83
                  Amazing! I've truly enjoyed your build(s)!
                  • #84
                    Why is everybody so excited about these?.....There's no Walnut left for the rest of us!!!!
                    Jeff your work on these is incredible,I give you two thumbs up...But I really wish I was all thumbs.
                    Regards
                    Bob C.
                    NLA
                    • #85
                      What a beautiful, happy family! Great work. You should be very proud.
                      Isn't it about time we started answering rhetorical questions?
                      Twitter: @undefinition1
                      • #86
                        Jeff,
                        I am enthralled with the amazing work you have accomplished on this build. I am currently working on a boombox made of solid walnut as well. You're projects has been of great inspiration to me! I only wish I had access to a wood shop like yours.
                        I had a few questions for you if you don't mind.
                        1) Have you had any issues with shrinking/expanding or swelling of the wood? That is my main concern with making a solid wood box. It is totally worth the risk to have such a marvelous work of art, but I was just curious of your experiences.
                        2)What size of joint cut did you end up going with? 3/8?
                        3)Any other tips and tricks you can offer that helped it go smoother?
                        Thanks again and amazing work!
                        JT
                        • #87
                          Originally posted by jtague87 View Post
                          Jeff,
                          JT
                          I used a 3/8" box joint. The lumber supplier I use supplies kiln dried hardwoods to local cabinet makers. So far, I have not experienced and issues due to seasonal movement or shrinking. That said, even though i was thorough when glueing the cabinets together i also took the time to apply silicone caulking at the inside of all of the joints.
                          Thanks,
                          Jeff
                          Projects:
                          • #88
                            This is truly an inspirational build! I'm fairly new to this addiction and now in the process of setting up a woodshop in the garage for the main purpose of speaker building (much to my wife's dismay...). I can only aspire to something of this quality! Really beautiful work, Jeff!
                            -Carbon
                            Carbon13
                            • #89
                              -Carbon
                              It took me a few years to ammass the tools and skillset to even consider building cabinets like these. A tablesaw and router will get you started. My advice is to take the time to research the tools you buy. It's much cheaper to buy a quality tool once than to buy a cheap tool that will fail and cause you to also purchase that quality tool later.
                              Ive only been woodworking for a few years. If I can do it, anyone can!
                              Thank you for the compliments on this build!
                              Thanks,
                              Jeff
                              Projects:
                              • #90
                                These Sprite's look great!! What are the dimensions you used because I know they are going to be different from Paul's?
                                I wonder how many people I've looked at all my life and never seen.
                                - John Steinbeck
