Helium - a true micromonitor
  • Re: Helium - a true micromonitor
    Originally posted by corradizo View Post
    All of my parts are in! I have a silly question about the port. Can I get 3/4 ID PVC and cut it at a 45 deg angle and glue the pieces together? Alternatively could I use 3/4" copper pipe?
    If you make the cuts with a chop saw or a table saw so that they're smooth and use the right glue you could probably get away with it. It's much easier, though, to use an elbow.
    You could instead use copper or anything you like. Even a cardboard tube.
      Thanks Herman, trying to save space in the box :-). I will pick up and elbow at the store and just see how it goes. Let the dust fly!
        For my Hafnium project, I actually did exactly what you describe - cut a 45 degree angle in PVC and glued the resulting two pieces together with PVC glue to make the port. I used a compound miter saw to make the cut. For my Helium prototype, I used a standard elbow.
        Sehlin Sound Solutions
          You can see the port on post 19 of the Hafnium thread.
            I didn't glue mine, friction alone holds the elbow on.
              Assembled! Need to glue them up and paint.. Note, the tape doesn't hold for much. A little bit of power and Hotel California blew the baffle off!! They already sound big, way bigger than you would guess and very clear. I series connected a 27 and 12ohm resistors to get to 39ohm and tried it on one. It seems to make them more "alive"? I like it better, though I do not have a trained ear. Thanks so much for this great design in such a small package!! My first non-sub speakers rock!!
ID:	1165870Click image for larger version
                I've got a couple of blown ND90 with the magnet removed. Could they be used as a passive radiator? WinIsd sim would require adding 6 grams to get the same response curve (using published specs). Anything I'm missing?
                  Good news for prospective Helium builders! PE is now offering a full range speaker starter kit that includes the ND91-4 and the knock down enclosure kit for approx $70, which is $12 less than buying separately (part number 300-7100). Add the tweeters and crossover parts, and you can have Heliums.
                    That seems like it should work as long as everything moves freely. You might try to find some lead tape (golf and/or tennis shop should have it) to add the weight.
                      Link?
                      Edit: Never mind. Got it. Overlooked the part # in your post.
                        That's awesome, they sound so nice!!
                        I am thinking to try the Overnight Sensations next. Cannot think of a better gift to give to a friend.
                        Thanks again!
                          Wow....not too shabby!!!
                          Here's the link: http://www.parts-express.com/dayton-...encl--300-7100
                          Bryan K.
                          Midwest Audio Club
                          Speedster | Sub Attaché | The Wildeman | Sean's NLA Towers | COÜGAR, COUGAR II and COÜGAR JR | Triton | Lithium | J-Boom | Trym MLTL | Docere MLTL
                            PE should mention this in the product description as a better-sounding alternative to the less-expensive full range option. Make it a one-click purchase option.
                              I'm so tempted to get parts for these, I already have some ND91's in small ported cabs out in the garage, I'm half way finished already, lol.
                              My modest builds:
                              Armadillo TM, A.K.A. Lil' Dillo
                              Tarkus/Armadillo build #2
                              Armadillo Center Channel
                              Au-Rock-O Sub
                              Tarkus
                              Staining MDF tutorial
                                Herman, can you check your inbox please? Thanks.
                                Bryan K.
                                Midwest Audio Club
