Originally posted by davidroberts
View Post
Helium - a true micromonitor
Originally posted by mga2009 View PostHi,
These are 4ohm, correct?
I am looking a set of satellites/surround to use my AVR, but I need 8ohm (6ohm at best) and found these while looking for JB's Quarks.
Since I modeled that crossover, I voiced the Helium soundbar, which uses the 8 ohm version of the ND-91. The crossover will work for the Helium cabinet.
Jeff, Scott,
Thanks for your replies.
Scott, so I just need to use the crossover design for the "Helium Soundbar" in the Helium standard cabinet. Regarding the XO, I noticed the 3 Ohm 5w resistor is no longer in stock in PE. Can I just use a 1Ohm and 2Ohm in series? Also, is there any chance to change the dimensions on the cabinet, keeping the internal volume (and the components location in the baffle)??
I need them a little bit shallower and taller to get them behind my couch.
The driver spacing for the soundbar is close to the same as the original Helium, so it should work fine. The 8 ohm version of the ND-91 has a slightly larger optimal cabinet than the 4 ohm, but as a result can play a little deeper. The soundbar has isolated chambers for the left and right channel that would be 4" wide by 4.75" deep by 9" tall as stand-alone speakers. You could flip that around and make them 4" deep by 4.75" wide by 9" tall. The port for the soundbar is 3/4" schedule 40 PVC, 4 inches long.
Originally posted by scottsehlin View PostThe driver spacing for the soundbar is close to the same as the original Helium, so it should work fine. The 8 ohm version of the ND-91 has a slightly larger optimal cabinet than the 4 ohm, but as a result can play a little deeper. The soundbar has isolated chambers for the left and right channel that would be 4" wide by 4.75" deep by 9" tall as stand-alone speakers. You could flip that around and make them 4" deep by 4.75" wide by 9" tall. The port for the soundbar is 3/4" schedule 40 PVC, 4 inches long.
Thanks for your reply. Very clear explanation.
Regarding the XO and the 3ohm resistor, I remember from school that if I install them in series they sum up the individual resistance, but I don't know if this will affect negatively on the SQ or any other spec of the speaker design.
Thanks!
I'm intending to build these but to also incorporate a small sub and use the Sure electronics combination of JAB2 and JAB3 with DSP in 2.1 config to drive the whole thing. I can use the DSP to cross from sub to heliums. I'm just wondering if I need to do anything to adjust the passive crossover in the heliums to account for the DSP filtering the lowest frequencies away?
Originally posted by Chris Roemer View Postsure, but you probably can't go any smaller (chuffing), and bigger will make it longer (box fitment issues - also you'll lose a little interior volume). Be sure to check the tuning w/ith WinISD (or equivalent).
