2nd Annual Stock-toberfest
2nd Annual Stock-toberfest starts October 17th! Time to stock-up on great products at great prices! Click the Parts Express Logo at the top left of this page.
See more
See less
Cabrini Redux
  • #61
    Re: Cabrini Redux
    My assesment is in complete agreement Bryan.
    • #62
      Re: Cabrini Redux
      Is the redux tour ending? If not, how does one get on the list?
      Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
      Sites: Jupiter Audioworks - Flicker Stream - Proud Member of Midwest Audio Club
      • #63
        Re: Cabrini Redux
        Would this work laid on its side for a center channel, or would your all GRS small 3-way be better? My main objective is clear understandable dialog. Your comments are appreciated.
        • #64
          Re: Cabrini Redux
          I think the 3-way would make a better center, imho.
          • #65
            Re: Cabrini Redux
            I did build the original cabrini mtm as a center with the horn and cabinet horizontal and I liked it better than the tm bookshelves .... just saying... I still have some thoughts to upgrade them to the redux
            • #66
              Re: Cabrini Redux
              MTM- just so I understand, did you use 2 61/2" with the piezo horn?
              • #67
                Re: Cabrini Redux
                Yes that is correct. Look here http://techtalk.parts-express.com/sh...-Cabrini/page2
                Also keep in mind that I have not heard the redux version. But I will say this was a great first build and still enjoy the bookshelves and center as that is what I run out in the garage for for football and movies... the only place I can smokes cigars.
                • #68
                  Re: Cabrini Redux
                  Here is what I have come up with for my center channel: a WMTW in a horizontal cabinet with the GRS midrange and tweeter from Johnnys 3-way mounted vertically in the middle flanked by a GRS 6 1/2" on each side. I will use the crossover from the 3-way as a start, but with a 1.25 mh inductor and a 33mfd capacitor on the woofer. I'm thinking reducing the series resistor on the midrange to 5 ohms and removing the series resistor from the tweeter to allow for the increasesd sensitivity from the extra woofer. I'm not sure whether or not I need to increase the values of the series capacitors on the midrange and tweeter to allow for less resistance in the circuit. I know I would need a larger capacitor if the resistor followed the capacitor in the circuit, but I'm not sure where as in this case the capacitor follows the resistor. I'm using 2 6/12"s instead of the single 8" for looks, so I hope I don't screw things up too bad.
                  • #69
                    Re: Cabrini Redux
ID:	1171468Click image for larger version
                    Slow but making some progress. Cabinet for cabrini based center channel is ready to start finish work. I have built a crossover and tested by ear. I used the crossover Johnny designed for the large grs 3 way with less padding on the mid and none on the tweeter. Using a 2mh inductor and 66mfd capacitor on the parallel connected woofers, but that may change. I'm really encouraged by the sound so far. Dimensions are 9"h x 10.5" deep x 24" wide. 3/4" mdf.
                    • #70
                      Re: Cabrini Redux
                      Hey... that's great!
                      • #71
                        Re: Cabrini Redux
                        It is.
                        I knew him before he was famous.
                        • #72
                          Re: Cabrini Redux
ID:	1171679I have smoothed with bondo, sealed edges with shellack, primed and wet sanded. Should be ready for finish coats this weekend. Also have the crossover put together on a PE board.
                          • #73
                            Re: Cabrini Redux
                            another picture. Haven't figured this out yet.
                            • #74
                              Re: Cabrini Redux
ID:	1171702Click image for larger version
ID:	1171703Click image for larger version
                              My objective was easy to understand dialog and I think this goal was accomplished. This crossover sounds fine to me, but the woofer section probably could be improved upon. I like the looks and the sound.
                              • #75
                                Re: Cabrini Redux
                                Nice job, gives me food for thought...
