Cabrini Redux
    Figure 8 hasn't been here since 2018.
  • Eternal Student
    Originally posted by figure8 View Post
    Re: Cabrini Redux
    [ATTACH=CONFIG]63681[/ATTACH][ATTACH=CONFIG]63681[/ATTACH]
    Slow but making some progress. Cabinet for cabrini based center channel is ready to start finish work. I have built a crossover and tested by ear. I used the crossover Johnny designed for the large grs 3 way with less padding on the mid and none on the tweeter. Using a 2mh inductor and 66mfd capacitor on the parallel connected woofers, but that may change. I'm really encouraged by the sound so far. Dimensions are 9"h x 10.5" deep x 24" wide. 3/4" mdf.
    I see the box dimensions but do you have the driver locations for the baffle and the impedance for this center channel? I'm curious if it would work on my el cheapo 5.1 receiver that can only handle 8 ohms so I can have this to go along with the regular Cabrini Redux's.
  • johnnyrichards
    Yep, with the understanding they will be output limited due to the short Xmax on the woofer.
  • Kered
    In your write up on these, you mention a vented tower version. Would you still recommend that as a build?
  • Kered
    Thank you for the update. I keep these in the speakers I want to build list. I have a full set of parts for the Le Singe Sarcophage, just don't have the room for them. Hopefully they can be my garage speaker if I ever get one.
  • johnnyrichards
    Zombie thread. The waveguide did not play well with that woofer, so no update there.
    However, it is now cheaper today than six years ago to build these - including an upgrade to a poly cap. The slightly larger coil should bring the mid-range down a touch, as well.
    Plus, now the drivers and XO components ship free. Add some binding posts and a bag of polyfill.
  • johnnyrichards
    Cabrini the Last in the works. Have to resize the tweeter cutout slightly, but otherwise it should be a pretty quick conversion.
    These were on the road for 2-1/2 years or so... Not sure what is in store for them after this final upgrade path, but as playback monitors in a studio they would probably work pretty dam good, actually. Not for mixing, mind you, but for playback.
  • thekorvers
    Re: Cabrini Redux
    Originally posted by Eternal Student View Post
    I've been trying to figure out the crossover and it's a bit blurry so I redid it in SchemeIt but I'm not sure the values and model numbers of the drivers are correct. Can you look it over and see if they are correct?
    [ATTACH=CONFIG]64135[/ATTACH]
    No, I don't think that would work very well! I do believe that you need some kind of return path for the little electricsicles!:D
  • figure8
    Re: Cabrini Redux
    Yep; that's it. Midrange has polarity reversed.
  • Eternal Student
    Re: Cabrini Redux
Name:	Cabrini Redux CC.png
  • careyink
    Re: Cabrini Redux
    [ATTACH=CONFIG]64047[/ATTACH][ATTACH=CONFIG]64048[/ATTACH][ATTACH=CONFIG]64049[/ATTACH]
    My objective was easy to understand dialog and I think this goal was accomplished. This crossover sounds fine to me, but the woofer section probably could be improved upon. I like the looks and the sound.
    Nice Job I really like the look...
  • johnnyrichards
    Re: Cabrini Redux
    Nice job, gives me food for thought...
  • figure8
    Re: Cabrini Redux
ID:	1171702Click image for larger version
ID:	1171703Click image for larger version
  • figure8
    Re: Cabrini Redux
    another picture. Haven't figured this out yet.
  • figure8
    Re: Cabrini Redux
ID:	1171679I have smoothed with bondo, sealed edges with shellack, primed and wet sanded. Should be ready for finish coats this weekend. Also have the crossover put together on a PE board.
