1 of 2 < >
Midwest Audio Fest
It’s that time audio enthusiasts!
Registration for the 2019 Speaker Design Competition is now open! Visit midwestaudiofest.com for details and to list your speaker project.
We are excited to see all returning participants, and look forward to meeting some new designers this year, as well!
Be sure your plans include a visit to the Parts Express Tent Sale for the lowest prices of the year, and the Audio Swap Meet where you can buy and trade with other audio fans.
We hope to see you this summer!
Vivian and Jill
2 of 2 < >
Midwest Audio Fest
See more
See less
My First DIY Build - SB15NRX30-8 & SB26STCN-4 (pic heavy)
  • My First DIY Build - SB15NRX30-8 & SB26STCN-4 (pic heavy)
    *****REVISED 8/28/2015***** After good input from MWAF. I was told they didn't have enough mid-bass and too much bass (muddy). SO I went back to the drawing board and revised the XO focusing on increasing the BSC and trying to get the flattest response while keeping the XO count within reason. I still have a 2nd order on the woofer and 3rd on the tweeter. The result is a much better overall tone and smooth sound and I can listen for hours without any fatigue and another important factor i considered was that they needed to play with most any kind of music, which now they do - MP3, FLAC, Pandora, even youtube sounds good. I have updated the pictures and graphs to the new design and removed the previous version, because I don't think it merits retention.
    First off, a big thanks to Todd England (Speekerbldr on Meniscus) he was nice enough to give me a great deal on a pair of SB Acoustic SB15NRX30-8 (coated) mid-woofers and give me a TON of advice and guidance through this whole process. I asked for and received some great input on a good small frame (70-80mm) tweeter to pair with the woofers, so thanks Jeff B., Chris Roemer, Wolf and everyone else. I was contemplating the new CSS LD22(F/C) or the SB26STCN and Jeff Bagby suggested the SB26STCN-4 and how could I not trust Jeff. I then proceeded to ask a lot of XO questions and box alignment questions to try and get started back in September and October. I finally decided on a similar design as Jeff B's Kairos design, in that I chose an alignment that lends itself to either ported, or sealed depending on the users situation and/or preference.
    The cabinet ended up 12"(h)x7-1/2"(w)x10-1/2"(d), or about 9L and after taking away for the drivers and a brace I figured I'm close to 8.5L, using 3/4" stock/baffle. I tuned the port with a 1-1/2"x4-1/3" single flared port from PE This gives a port tuning of 52-Hz with a bass-shelf alignment of about 1-2 db in the vented form and a very nice 0.66 Qtc in sealed form. It gives an F3/F6/F10 of 58/51/44 (Hz) in ported form and 75/55/41 (Hz) in sealed form. It also SIM's to provide 102db ported and 100 db sealed with 25 watts of power, both being right at Xmax. I can attest, they are plenty loud in my office (12x16) and my living room (20x24) which is also open to a kitchen/breakfast nook.
    Speaker locations - tweeter is 2-1/2" down and 3/4" offset with the woofer down 7-1/4" and centered on the baffle. Port is directly behind tweeter, centered on back panel.
    I have had countless amounts of help with this build which has taken me close to 3 months to get completed. Some of that is because I didn't heed some very important advice from the beginning...get a mic and testing software. So after "playing around" for over a month without getting much done, I sprang for OmniMic and then the build really got going and was finished within a couple weeks (not including the finishing).
    The finish is Mottled Sapele with 5 coats of Arm-R-Seal (gloss) wiped on and sanded with 220 after the each of the first two coats, then 330 grit for the next 2 coats. The final coat was a light-medium coat that was left as is. I have previously gone back and waxed this type of finish, but it is pretty nice as is. I will give one warning, this veneer was 1/66" thick, raw and quite brittle. If you decide to use it, spring for a paper-backed or thicker version. It will save you a lot of the cracking and splintering I had to work through. But it might be the most gorgeous veneer I have seen, almost a 3-D effect depending on the angle of view.
    Without further delay... here's what you really wanted, the PICS!
    Paul
    The "SB's" build page
    http://techtalk.parts-express.com/sh...-4-(pic-heavy)
    Re: My First DIY Build - SB15NRX30-8 &amp; SB26STCN-4 (pic heavy)
    Couple pics in my living room. I wanted to listen to them in different rooms before I decided on the final XO design.
ID:	1162895Click image for larger version
    Gotta love this veneer...although out of these three pics the last one looks like it has finish on it, it doesn't they were all taken the same day and with no finish, they are completely raw veneer.
ID:	1162897Click image for larger version
ID:	1162898Click image for larger version
    Paul
      Not the best pics, since I was using an iPhone camera. Trying to get my sister in law (a professional photographer) to take some "completed" pics, but that hasn't happened yet.
      These are with either 2 or 3 coats, so not completely finished yet.
ID:	1162900Click image for larger version
      Picture of the OLD XO board, will update once I get the new version completed
      Couple pics of the "finished product" next to my Nano Neo's build. So far I have built the Nano Neo's, the OS's (TM and MTM versions), the CLASSIX II's (in Walnut veneer, same Arm-R-Seal finish and flat black baffle) and these.
ID:	1162903Click image for larger version
      Paul
        ***Revised 8/28/2015***
        Crossover is pretty straight-forward, 2nd order on the woofer and 3rd order on the tweeter. It helps to have some quality components to work with.
Name:	SB_New XO Design Layout_082815.jpg
        Here is the SIM Graph (Black) versus my Actual OM measurement (Orange)
Name:	SB_SIM vs Actual Measured_New XO_082815.jpg
        Here is the SIM with the reverse null
Name:	SB_FR Graph w Null_New XO Design_082815.jpg
        Impedance Graph
        SB Build_Impedence Graph.pdf
        Paul
          ***Revised 8/28/2015*** with updated graphs
          Here's all the Curves and plots.
          Raw FR Curves - tweeter, woofer and Both
Name:	SB_OM Combo Graph_27in_124_082815.jpg
          Final FR Curve at 27-inches at 1/24th octave
Name:	SB_FR Graph_27in_124_082815.jpg
          Distortion at 1/24th octave
          Tweeter Only
          Woofer Only
          Paul
            Very nice build and write up as well.
              Very attractive build you got there.
              Kenny
              http://www.diy-ny.com/
              DIY NY/NJ 2014 https://www.youtube.com/watch?v=FGwA...ature=youtu.be
              Man does not live by measurements alone, a little music helps.
                Nice work on your first build. Is that sapele veneer?
                My Build Thread's
                Carrera's / Finalist TL's / Speedster TMM's / Speedster MTM Center / Overnight Sensation Surrounds
                  Thanks for the kind words.
                  Yes, it's "Mottled Sapele" I got on clearance from veneersupplies.com. Great deal at $34 for 5 sheets of 11-1/4"x84", after book-matching and shipping it was $47. The only downside with it, was how thin it was cut. At 1/66" thick, it was very brittle and easy to get cracks and/or chip-out. Since it was on clearance, he didn't offer to paper-back it, or an option of a 1/42" thickness. Even a little bit thicker would have made using it a lot easier.
                  I love the look of it though and I think it was worth all the "issues" and difficulty I had working with it.
                  Paul
                    they look fantastic! I was going to guess beeswing Makore before I saw the last post. Yep, 1/66" is pretty thin. 1/42" definitely give you a little wiggle room, and you can even put a very small, hand sanded round over on the corners.
                    Do you love the SB26's as much as other folks on the forum? I've been wanting to give them a try. My favorites are the NE19VTT's so far, but the venerable XT25BG's are awesome too.
                    nikkoluvr
                      I've been eye balling the redwood burl he has. The option for paperbacking a burl is crazy it adds like $100! There are so many veneers to choose from on that site it is insane. I go there an just browse a lot trying to get ideas. How was the shipping of the brittle stuff? Did it come in a large box I assume he couldn't bend it at all? Also, what glue method did you use contact cement, cold press, heat lock etc.?
                      My Build Thread's
                      • #12
                        nikkoluvr
                        They are very nice, while I don't have much reference since this is only my 5th build and 3rd different kind of tweeter I've heard for an extended period. I was looking at the XT25BG's in small frame format, but Jeff recommended these, and I certainly trust his opinion. They are very easy to work with, which for me was a real help in the design aspect. They sound good and easy to design a XO for, that's a check and check moment. For $35/ea, you really can't go wrong with them as long as you like the look.
                        I totally agree with you, going online to "find" veneer results in a lot of head-spinning and indecision. I went back and forth on Curly Eucalyptus, Makore and Teak, but thought for the price I couldn't resist getting a really high-end looking veneer on the cheap. They just rolled it about 12" in diameter with paper between the sheets and put in in a pretty big box with packing paper all around. It was split on the ends, but only about 1-2", so I still got 80+" out of each sheet and the width was completely usable. It is fairly flexible, especially if you wet it slightly with some distilled water, just brittle on the edges when it dries out.
                        I used the iron-on method (1st time using this process too) with Tite-Bond Premium. I put 2 coats on the MDF, letting each coat dry for about 45-60 minutes, then 1 coat on the veneer letting it fully dry at least 45 minutes. Then with a dry (no water in the iron) and running it at "wool" setting (highest, no-steam setting). I laid the pre-cut veneer pieces on the box exactly where I wanted them and ironed them on, which only takes 2-3 minutes on each panel. Followed up with a veneer scraper to make sure it was fully adhered, especially the edges. Also found out if you wipe the veneer with just a little water, it kept it pliable even with the iron on it (iron tends to dry it out and it really wanted to crack/split) Only real issue with that was if you didn't let the glue completely dry, it acts like contact cement and when they touch, it's down for good. I used almost half of a quart of the Tite-Bond to do both boxes and used 2 sheets of the 5 sheets of veneer. So I have enough veneer to do at least another pair of monitor speakers.
                        Glad to answer any questions, I was kind of "flying by the seat of my pants" on this build. Since I was new to testing, new to designing a XO, new to 45-degree cabinet joints, new to raw veneer and new to the iron-on veneer method. So just a couple new things I now have in my arsenal for future projects.
                        Paul
                        • #13
                          The 45's look great. I think i will try this on my next build. Is it 1" mdf or does the 45's make it seem thicker. Did you use screws or nails or battons to secure it? I figure if you use decent quality veneered ply you can skip alot of the veneering process. Was it difficult to get the back and from on with those being 45'ed as well? Im wondering if you jist cut everythibg to size and mocked it up to verify it fits then used the 45 on the table saw.
                          My Build Thread's
                          • #14
                            It's just 3/4", but the camera angle and 45 does make it seem larger. I just set my table saw at 45-degrees and measured all the panels on the long side.
                            (Ex. I cut the first 45 just taking off an 1/8" or less, then set the fence at the desired outside measurement and run it through with the 45 side running down the fence. So if you put your tape measure on the "long" side it should read you panel measurement, i.e. 7" needed, tape measure should read 7")
                            I just used Tite-Bond regular glue and did the top, bottom and one side, then the brace, back and other side, then the front. I always go back and run a small bead of glues along all the interior edges, so any minor "misses" on the gluing will get a good bond after that.
                            Yes, you could totally get away with using Birch or Oak veneered ply and cut out 4-5 hours of the veneering process. Some people don't like 45's because there isn't any "edges", but from seeing and reading on here, most of you guys like the solid look... me included.
                            Paul
                            • #15
                              updated a few pics and added two new graphs on post#4 showing the PCD SIM and Actual OmniMic Graphs...I couldn't believe how close they are, you can barely tell the gray (actual) line is there. Still working on getting some more professional final pics posted.
                              Updated out the XO schematic in Post#4. As I learn more, I get better, so this updated XO is a much better sounding version (granted I only change the woofer capacitor from 7.5uF to 12uF)
                              Paul
