The Quarks - M.O.S.D. Computer Speaker
  • JB thinks the FE-85 could be substituted. Why not try that?
    • Thanks for replying Chris. I have already bought the woofers and tweeters, so I am looking for peoples knowledge on whether these components could be used in the Quarks build. I do not have the capability to measure these woofers at the present time. I may have to resort to a build and see effort, but I would like to get some comments from some of the builders here before starting to build.
      • Funny, I didn't realize it but I've got a pair of those on the bench (apparently they're Dayton DS90-8s). They'll PROBably work OK as a 3" woofer in that box. Same vent. I'll look at the XO later (today maybe). I wouldn't call them the "Quarks" though, maybe the "Charms". (Hope JB doesn't mind).
        Anyone got a schematic or XO description?
        • Originally posted by Chris Roemer View Post
          Here you go
          • Originally posted by Kootskid View Post
            Possibly build these? http://techtalk.parts-express.com/fo...0-minute-dsa-s
            • Jeff, Chris,
              Thanks for taking the time to contribute to this topic. I like the speakers that mattp built, and will consider them along with the Quarks (Charms). If I remember correctly I bought enough tweeters and woofers to make 3 pairs of speakers. I am wondering if a set of Helium's could be made also with these woofers. I am going to mess around with some box designer software, using the dimensions that other builders have used, to get a feel for what these 3 inchers can do. Please keep as much info as possible coming, as i am a rookie and flying by the seat of my pants. Sure is fun though!!!!.
              • Originally posted by Jeff F. View Post
                Different beast!
                • You can't call a Quark a Quark if you use different drivers. Same applies to the Heliums or any other design.
                  I don't want to dampen your spirits, but let's begin with stating the request properly: You have "x" drivers and you would like to receive some help using them in a design. Then let's start a new thread so as not to sidetrack this one.
                  Since that buyout driver is equivalent to the current DS90, the design would have some longevity:
                  https://www.parts-express.com/famous...river--299-422
                  https://www.parts-express.com/dayton...8-ohm--295-422
                  I know of two designs using that mid, which could give you some ideas. There may be more. The PEDS use a Daton ND16FA tweeter, very similar to the ND20FA's you already have:
                  http://techtalk.parts-express.com/fo...roject-Done-*=
                  http://techtalk.parts-express.com/fo...highlight=peds
                  • After you have started a new thread, listen to what Chris Roemer has to say. He is very knowledgeable and helpful.
                    • Originally posted by thekorvers View Post
                      Different beast!
                      Yep, good catch. I didn't realize they made paper and aluminum cone versions of this model.
                      • thekorvers, thanks for the advice. I had a new topic chosen, and had typed a few sentences and went to post. I got some message about not being able to post because I was not confirmed to be human. I tried to restore what I had typed, but it only booted me out of the forum.
                        If the moderators can delete my posts from this topic, it would be appreciated. I have contacted PE Webmaster to see what the problem is. Once it is solved I will open a new topic.
                        Sorry about hi-jacking the Quarks thread.
                        Myles
                        • If you look at the Quark XO, here's how I'd mod it to use the DS90-8 woofer (same box, and same vent).
                          The tweeter HP filter changes. Instead of a 2.7uF cap & 0.20mH coil, try a 5uF series cap (Dayton poly) and a 0.30mH shunt (to gnd) coil.
                          Also, for attenuation, take out the series resistor, and try an L-pad instead: 6n (ohm) series resistor, and 4n parallel.
                          Use a (Dayton) #20 coil, and 5w resistors would probably be OK w/a relatively low power system.
                          Positive polarity is indicated, but try the tweeter both ways and go with whatever sounds best to you.
                          The woofer needs a bit more than just the 1.0mH series coil (due to cone breakup around 8kHz).
                          I'd add a Zobel across the woofer: 10n resistor and 3.3uF cap.
                          Also run a "tiny" 0.22uF cap (027-402) across the 1mH coil. This acts like a notch (tank) filter.
                          You could probably go w/the "buyout" bobbin coil here (269-2124).
                          Fc around 3kHz, w/not much baffle-step (about +3dB).
                            Myles
                            Don't worry about your posts in this thread and you didn't really hijack this thread. I know that newbies sometimes have a hard time starting a thread, but are you sure you are human?
                            I don't consider this forum or PE's website or search engine to be particularly user-friendly, but fortunately they make up for it in customer service. You can't find another place as good to do business with.
                            • Thanks for the great sounding speakers Jeff! Sent from my SM-N900V using Tapatalk
                              • Thanks for the great sounding speakers Jeff! Movingui, Walnut stain, minwax tung oil finish and black suede-tex flocked baffle. Sent from my SM-N900V using Tapatalk
