The Quarks - M.O.S.D. Computer Speaker
  • #31
    Re: The Quarks - M.O.S.D. Computer Speaker
    I would appreciate a pic of an assembled crossover when someone gets one completed!
    Thanks!
    -Robert
    • #32
      Thanks!
      I would not recommend building a crossover board per se. I soldered leads onto the inductor and glued it into the corner of the box. For the tweeter's filter I glued the capacitor and resistor on top of the little inductor, soldered it up with leads and glued it into the opposite corner.
      • #33
        You make it sound so simple, but I can do that.
        Thanks!
        -Robert
        • #34
          Tip o' the hat to Erich as well, for these little boxes! ...the fit-up couldn't be nicer, or more convenient.
          Ed Henderson
          • #35
            Ed, does your statement mean that it is possible to purchase enclosure 300-7060 with the necessary panel cutouts for the Quark drivers and port ready-made? I was already contemplating building a pair or two; not having to router the cutouts would make the Quarks harder to resist! jonathan
            • #36
              Not that I'm aware of, Jonathan- I was just talking about the standard PE boxes, which come with a blank baffle (as you see them knocked-down in Jeff's first picture)... the way the pieces fit neatly together, you could probably build these without clamps in a pinch.
              Ed Henderson
              • #37
                I see, Ed. No problem - I thought that I spied a chance to be lazy and jumped at it .
                I plan to install the drivers behind the front panel rather than in front, so in any case I'll need to make alternative front panels out of a material that retains its strength even when rebated thin - probably bamboo plywood or Micarta G10 (FR4). jonathan
                • #38
                  For what it's worth, I didn't use a router. I used hole saws with my drill. For example, a 3" hole saw is perfect for the woofer. I used a 1" for the tweeter and port then used a curved file / rasp until I had a nice press fit. Simple tools that worked just fine.
                  • #39
                    Jeff, was the back of the front panel (for the mid-woofer) profiled in any way, or did you leave the front panel cutout edge unprofiled, on the assumption that 0.5-inch panels aren't worth the effort?
                    • #40
                      Well, it looks like I am building 2 tiny hinny speakers with tiny hinny drivers.......The little woofer is hefty more toddler like!!!! :eek::p;)Click image for larger version
ID:	1165546Click image for larger version
ID:	1165547Click image for larger version
                      Ahhhh.....just got those "Iddie Biddie" crossovers!!!! LOL!
                      However, Jeff how does one remove the inner core of the inductor?
                      Thanks,
                      Roberet
                      -Robert
                      • #41
                        Jeff didn't use those buyout coils. There is a comment in the reviews of the coil re: how to do that.
                        • #42
                          Thanks, djg, I will check it out.
                          R
                          -Robert
                          • #43
                            Probably just drilling the hole bigger with a regular drill (carefully) would give you enough purchase on the core to knock it out with a punch. In fact, I have two of them. I can see the core through the small hole. A very small punch could probably get it, if it isn't bonded in there too tight.
                            • #44
                              Nope, just a hole.
                              • #45
                                Thank you, Jeff. One more question if I may. Do you have a system response curve with inverted tweeter polarity, to show the phase integration between drivers? I am debating whether to build your Quarks or Scott Sehlin's Heliums.
                                I live across the Pacific, and shipping costs will be high, so I am trying to make a reasonably well-informed decision.
                                Many thanks in advance! jonathan
