Infinity IMG driver
  • Infinity IMG driver
    I found a crack at the 6" IMG midbass of my Refernce Six. Can this be repaired? What can be used in sealing a small hole at foam surround? Pls help. Thanks.
    Re: Infinity IMG driver
    You can try a thin layer of silicone rubber, but your surrounds are most likely rotten, and will descinigrate tomorrow! Get new ones here at PE.
      You can do a search on Ebay for "Infinity woofers" and find replacement drivers & re-foaming kits touted as being designed for Infinity drivers.
      If the foam surrounds are still good, you CAN do the "Dab O' Silicone" repair method.
        > drivers.
        > repair method.
        Thanks.
        This is a question back to Chris. What would be a good and closest replacement driver without modifying the xover since I don't have the skills. I believe the range was from 200 to 1.5K hz and the whole tower is rated for 225 Watts, 6 ohms & 90 db, the speaker outside rim is a little bit less than 6-5/8". What would be a possible improvement replacement for the 10" woofer in this sealed box. I believe the sealed box volume is ~ 2 cu. ft.
        Thanks.
