raspberry pi tube amp hat...
  • raspberry pi tube amp hat...
    Anyone else intrigued by this...
    http://www.geeky-gadgets.com/raspber...es-03-05-2016/
    Carbon13
    Sweet!
    Tangband W6-sub
      That's not the kind of hat I was hoping for, but still pretty cool.
        Agreed, it is sweet, cool and intriguing all at the same time. I guess the vacuum tubes would warm up by the time the OS to completes its boot on the pi?
          looks like an imitation of this:
          http://diyaudioprojects.com/Solid/12...LM317-Headamp/
          just don't have high hopes for great sound
          btw, I do use raspberry pi 2 with the IQAudio DAC, now that is great sounding, will not be spending any more money or time searching buying
          other DACs, it is great enough for me.
            So, an I2S DAC + a hybrid headphone amp for $99, not a bad deal.
            My Statement monitors
            My Piccolatas
            My LM3886 amp
              Originally posted by Bengali
              btw, I do use raspberry pi 2 with the IQAudio DAC, now that is great sounding, will not be spending any more money or time searching buying other DACs, it is great enough for me.
              I have this same DAC and am totally pleased with it as well. I'm using the line outs to my amp in my main system, not for headphones. Once I got 'hardware volume control' working on the pi 2, its performance is equal to that of my Oppo BDP-83.
                I really want to try one out, but it isn't compatible with J. River(yet). It does look really cool though.
                http://www.diy-ny.com/
                  I'm trying to use the IQ Pi-DAC with a Pi3, without much success. I'd like to use it with an external CD/DVD player and thumb drive, given I don't have access to effective, inexpensive broadband radio or streaming services at home. I didn't think to order the SD card, and haven't been able so far to burn any of the images from the IQaudio website, though I did burn a NOOBS image for the PI3 and it works, less the Pi-DAC. I'd appreciate any suggestions for sorting this out. Thanks in advance.
                    What Pi-DAC are you using?
                    What are you using to "burn" the images?
                    My Piccolatas
                    My LM3886 amp
                      I have the IQAUDIO Pi-DAC, and an R-Pi3. The Pi works well with a R-Pi touch screen using an SD card I burned/flashed.
                      I used SDFormatter, then extracted the IQAUDIO quicktest file to the SD card. I tried both quick format and a complete erase and re-format on 3 different SD cards. I also tried the Rune Audio file and a few others on the IQAUDIO website, but without success.
                      I'm waiting on an order of new SD cards, thinking those I have may be corrupted. Although that doesn't make sense given I reformatted one of these and it currently runs the Pi3 without problems.
                      I wonder if the latest IQAUDIO pcbs, may not be entirely compatible with the Pi3. I have a Pi2, but it has developed an entirely different problem, that excludes using it to test the IQAUDIO Pi-DAC.
                        I believe that you need a Pi-DAC+ to use it in the RPi3. Could you verify that you have the + version?
                        If not, you may need an older model RPi (non + and non numbered) for that DAC.
                        My Piccolatas
                        My LM3886 amp
                          I just checked the sales receipt, it is the Pi-DAC+. I should receive new SD cards in a few days, and I'll try burning/flashing a new one. It was interesting that the Pi booted from the regular Raspian SD card, with the Pi-DAC in place. Although the Pi-DAC wasn't recognized. With Pi-DAC in place, I was able to play music through the Pi-3, using the 3mm jack' or the HDMI connector to an HDMI splitter connected to an amp. I may also try to make the recommended changes using the terminal once I understand the Pi better. Sent from my LG-V495 using Tapatalk
                            Have you tired downloading the files from the source?
                            For example, Rune Audio:
                            http://www.runeaudio.com/download/
                            http://sourceforge.net/projects/rune...mg.gz/download
                            I'm using the hifiberry DAC in a old RPi B model with no problems, tested Rune, Volumio and PiCorePlayer.
                            If you are using a windows computer, try using Win32Diskimager to burn the image. If you have problems, try USB Image tool. RuneAudio's documentation is quite comprehensive:
                            http://www.runeaudio.com/documentation/
                            My Piccolatas
                            My LM3886 amp
