Port size question
  • Port size question
    I'm getting ready to embark on my first project. I have two Dayton Audio 5-1/4 Woofers (DC130BS-4) and two Dayton Audio tweeters (DC28FS-8). I want to make some bookshelf speakers but first I want to do some experimenting. I want to make one woofer cabinet that is sealed and .78 ft cubed and one ported at 1ft cubed. My problem (that I am aware of) is; I don't know how to figure out what my optimum port size should be.
    My goal in this project is to learn how to build some cabinets and hear how drivers can sound differently and play with different crossover levels to get the sound I'm looking for.
    Can somebody tell me how to figure out a good port size for this driver?
    Thanks,
    Jay
    1st slight misconception which will become quickly apparent is that port calculators* are not directly dependent on driver data but rather internal volume and desired tuning frequency as part of a system response.
    * just 1 example:
    http://www.mobileinformationlabs.com...0lenth%201.htm
    The selection guide:
    http://www.parts-express.com/resourc...election-guide
    Suggests 72Hz
      Originally posted by DRD2 View Post
      Dayton Audio 5-1/4 Woofers (DC130BS-4) ... one woofer cabinet that is sealed and .78 ft cubed and one ported at 1ft cubed. My problem (that I am aware of) is; I don't know how to figure out what my optimum port size should be.
      Thanks,
      Jay
      Those box dimensions (net internal for the woofer) are way to big for the DC130. And the DC130 really wants to be ported (not suitable for a sealed box).
      I'd go with a ported box of .36ft^3 tuned to 50 hz using a 5" port with an inside diameter of 1.61" (that's the inside diameter of 1.5" PVC pipe). That will give you an F3 in the lower 50hz range. But you'll have serious excursion issues when pumping a full 30w into that - I'd say 15w max and you're still exceeding xmax by a bit.
        Also, look into WinISD (exactly what Mike used in the above screenshot). Modeling a woofer in a box is invaluable in making these kind of decisions, and the port dimension calculation is included.
        Wogg Music
          A port dimension is included, though not necessarily the best one. To get it right you need to model the cab with the expected maximum power input, make sure that the port velocity is between 15 and 20 meters/second. If the velocity is too high more port area is required, if less than 15 you can use a smaller port area to keep the cab size down.
          www.billfitzmaurice.com
            Baby steps Bill! Jay was just at the "I'm going to build a box and see what happens" phase in speaker building
            Wogg Music
              But he'd hardly be the first to use a port size that's fine for a 1w input and then wonder why it chuffs like mad with 100w. Just as you need to measure twice and cut once you need to model twice, or thrice, and build once.
                Great more info to keep me up at night. Seriously, this has taken off to be sort of an obsession and I have yet to make one cut or solder. Home brewing was my last hobby and I decided to get out of it for various reason. The similar thing I like about messing with speakers is the huge amount of variables that will affect the outcome. I can't wait to get started on a couple of boxes to see how they sound for myself.
                Thanks for the help!
                Jay
                  Great more info to keep me up at night...
                  haha ( not worth loosing sleep over ).
                  Often the 2nd question is: "why not use the smallest port possible?" ( Mike tipped you off on that )
                    Jay
                    Have you thought about building an existing design? There are many kits out there. Some have an available pre-cut baffle or an entire knockdown box to assemble. The kits that are for sale (some at PE, many elsewhere) were designed by Pros with years of experience. The designs have been validated many times (that's why they're for sale). And there are many choices for all budgets. You'd get the DIY feeling AND a great sounding speaker.
                    PE has the BR1 kit for ~$180 including cabinets that uses a 6.5" version of the DC series woofer and a similar tweeter. You could return the drivers you have to PE and just eat the shipping costs. You'll wind up spending the difference on crossover components and other "stuff" to complete a self designed unit anyway.
                    Note: I spent two years coming up speed on speaker design before I designed and built from scratch (I had a very specific need).
                    This 2-way FR graph accounts for Baffle Step and Diffraction ...
                      If you have time and wood to spare, I think there's great learning potential in building a couple crappy enclosures and observing how the speaker behaves in real life.
                      Wogg Music
                        +1 I have done this exact thing...I still have 5 of those "crappy" enclosures in the garage, can't bring myself to just throw them away.
                        Paul
                        The "SB's" build page
                        http://techtalk.parts-express.com/sh...-4-(pic-heavy)
                          Thanks,
                          Jay
                          Hello from Australia
                          I haven't built them, but Curt Campbell's website has exactly what you're looking for: the " TriTrix MT" which use the same drivers and a ported cabinet, and a simple crossover. Many, many people have built and loved the Tritrix, maybe consider this option?
                          Geoff
                            I did a quicky model in a ported box with a net volume of 0.35 cubic feet. Using a port with a 2" ID and 6" length, the tuning frequency was ~56 Hz and f3 was ~52 Hz. An input of 10 watts created an output SPL of 98-99 dB (not counting baffle step losses) with the driver exceeding Xmax at all frequencies below ~49 Hz and with the peak air velocity in the port of ~10 m/s at 50 Hz.
                            Paul
                              Geoff
                              Great eye ...
