Niles amplifier thumps when power off
  • Niles amplifier thumps when power off
    Hi!
    I got an used digital Niles SI-250 amplifier (link below) that thumps only when turned off.
    I 'm worried it can damage my loudspeakers as the woofer cone moves so far.
    Any experiences with this amp?
    THX
    http://www.nilesaudio.com/product.ph...rdcdID=FG01701
    Are you using the front power switch to turn off the unit or are you cutting the AC to the amp using some external control (e.g., power strip switch)? Also, have you tried the auto sense turn on/off to see if the same problem exists when the amp turns itself off?
      It probably relates to the order that you power up and power down your components - try shutting off the Niles power amp before powering down the pre amp or AV receiver that is feeding the input of Niles power amp ;)
        To Mike and Coke thanks for your reply. I've tried all yours suggestions and the problem remains.
          Is it a 2 prong plug on the amp? You might try flipping over the amp cord into the wall outlet/receptacle. You can if the amp cord/plug isn't "polarized" otherwise you'll need an adapter. Sometimes you can install (if you know how) a sparking capacitor across the On/Off switch contacts and that will kill some of the On/Off pop, but not necessarily the thump. I almost always retro fit my equipment with a sparking capacitor across the On/Off switch. A "thump" is usually a large current draw, which would benefit from some sort of soft start. If the amp never thumped until now, then that would be indicative of a growing problem.
            Some amps do that, it usually isn't a problem. I can't say if it's normal for this amp.
            www.billfitzmaurice.com
              Agree with Alan here about the soft start. However, stick to the following start up and shut down sequence to prevent thumping your speakers:
              Start up: Amp --> Preamp --> Source
              Shut down: Source --> Preamp --> Amp
              Let us know if this helps.
              Hong
              LM4780 Parallel Chipamp
              Sonata Soundbar Project
                Hong, that's exactly backwards of what I do and what I'd recommend!
                Paul
                Hong
                  Heck, you're right Paul. I'm allowed one stupid mistake a year, am I not? All my built amps have soft starts, so I guess the sequence doesn't matter, hence MY confusion. Sorry abn1701.
                    Yep, you're allowed one stupid mistake a year, and when you get to be my age, you're allowed to have numerous "senior moments" all year long, stupid or otherwise!
                    Paul
                      Paul
                      Yeah, but you know how badly it hurts being corrected by someone older than you are... (insert crying emoji here).
                        This is strange.
                        I opened the amplifier and it has sof start .When power on the relay clicks and so when turned off. So the protection circuit appears to be working
                        I'm really confused why the amp thumps when turned off only.
                        Cheers
                          It is odd, the relay should disconnect the output devices before a turn off thump occurs.
                            I have a carver amp that does that.....It started to happen after I changed some bulbs on the unit. After a google search looking at the service manual there is mention that there is some sort of relationship between the two. I'm considering placing the old bulbs back to confirm it :-)
                              I have had a few amps that thumped when you turn them on but most of them didn't make any sound through the speakers . Only the amp it self made the sound .
