Let's post something interesting: the ultimate small speaker build thread.
  • Let's post something interesting: the ultimate small speaker build thread.
    I was going to reveal this when it is finished, but seems like this forum needs a boost, so I'm going to post this prematurely. Here it is,
    The ultimate small speaker: The Reference Mini
    Design goal: Build the most accurate, highest fidelity, and highest bass output small speaker possible with DIY components without any budget limitations.
    I started DIY in order to build a great sounding small speaker with good bass, because I couldn't buy something like that on the market. I got sucked in by DIY and it is just exhilarating to design and build speakers that sound better than what I can buy at a store. I really enjoy pushing the boundaries of performance, and I was really curious on how far I can push small speaker performance, and how good I can possibly make a small speaker sound. This is the first time I allowed myself to be careless with budget with anything. This curiosity and one time budget freedom led to this incredibly fun, and absolutely insane project. I should check myself into DIY rehab after this.
    Shout out to JavadS and Kevin K for being incredibly gracious in helping me out with this speaker. I couldn't thank them enough for bringing this project to life.
    Forget about any preconceived notions of small speaker. This entire project is about figuring out how to get all of the normal sized bookshelf/floorstanding speaker performance from a small speaker. Originally it was thought it will still be inferior and a compromise to normal sized speakers, but turns out it is possible to do significantly *better* than normal sized speakers.
    Design summary: this speaker is 6.25" x 11.5" x 7.5" HWD. It is a 3 way, 4 driver, 2x passive radiator internally amplified active DSP design. It is specially designed so it can be used horizontally or vertically with no performance degradation. A pair can play over 100dB at 40Hz and 110dB when paired with a sub.
    A little video to demonstrate the bass capabilities.
    Tweeter: Scanspeak Illuminator D3004/6040-10 1'' Beryllium Dome Tweeter
    Midrange: Scanspeak 10F/4424G 4'' Neodymium midrange
    Woofer: 2x Custom Audio Technology 5.5" woofer
    Passive radiator: 2x Tang Band PR14 oval passive radiators tuned to 42Hz
    DSP: MacBook Pro with JRiver
    Amplifier: 2x ICEpower 100AS2
    Here's a picture of the test enclosure to give you an idea of what the speaker looks like. There is a second woofer behind the speaker that you don't see in this picture.
    I'll start by listing out the features of this speaker that makes it superior to most normal sized speakers. This is very long. Read the paragraphs below each feature if you're interested for the details.
    Controlled directivity with cardioid radiation pattern
    You can have the perfect speaker, but put it in a room and the room acoustics will muck it up and prevent the speaker from performing its best. Therefore, controlled directivity is a must to achieve a very high level of performance in a room to reduce the room interactions. This speaker uses a heavy DSP approach to achieve controlled directivity instead of using waveguides. It uses multiple drivers playing variable phase shifted signals to achieve a cardioid radiation pattern down to around 100Hz. A waveguide that can do that would need to be several feet wide!
    This is more important in a small speaker because the baffle step loss happens quite high, close to 1000Hz, and the distance to the wall would drastically change the sound of even a properly designed small speaker. By controlling directivity down to ~100Hz, there is no need to worry about the varying baffle step loss depending on the distance to the wall since the sound is only radiated forward.
    A 3 way that acts and measures like a single driver point source speaker
    Unlike pretty much any multi-way speaker, there is no horizontal or vertical lobing error. Two sound sources couple as one when spaced between 1/4'' of their wavelength.
    By using crossover frequencies equivalent to 1/4'' of the wavelength of the CTC distance between the drivers, the 3 drivers acts as a point source, and we get the massive advantages of multi-way and point source without the disadvantages of both (or coaxials).
    In order to do this, the spacing between the tweeter and midrange must be minimized to the extreme. The frame of both the tweeter and midrange are truncated in order to place them as close as physically possible to achieve a CTC distance of about 2.2", which still dictated a 1300Hz crossover. This tweeter has exemplary distortion performance, and with a steep crossover the tweeter can be made to handle this.
    Stunning bass extension and SPL for its size
    As a bass head, a huge priority for this speaker is to get as much bass out of a small speaker as possible. I want the speaker to play so deep that Adele can roll in it! This is perhaps the most fun part of designing (and listening) to this speaker, and perhaps the biggest shocker when people hear this speaker. The result? This 4L speaker should produce 96-111dB from 40-100Hz, 1M outdoors! Add 3-6dB for a pair (gain depends on distance between the 2 speakers and the frequency), and another 3-6dB when placed in a room! I expect a pair to produce a peak of 105-117dB of bass from 1M away in a typical room. Small speakers can't have bass? This one should be able to outperform some floorstanding speakers.
    To do this, a custom woofer is needed, and Audio Technology has been fantastic to work with to make a custom driver. Most drivers that are good for high output deep bass have low sensitivity and does not sound good up high. So Audio Technology made me a driver with high sensitivity (90dB) that can also do deep bass. It also has a very low Fs with a large 2" voice coil for extra power handling needed. The voice coil is made of a combo of kapton and aluminum to reduce eddy currents that cause distortion for better sound quality. The frames are truncated to reduce size to fit the biggest woofer possible in such a small speaker. This driver made it possible to maximize both low bass and upper bass/low midrange output.
    Multi-band compressor
    In order to get 38Hz extension from this tiny speaker, up to 17dB of bass boost is required. This is usually problematic because the speaker quickly runs into excursion limits, and very much limits the maximum volume for the speakers to be safely played at (by as much as 17dB). Therefore, a multi-band compressor is used to limit the woofer's deep bass output to below its limit without affecting the rest of the woofer band. This allows me to get the most out of the speaker at any volume by having very deep bass extension at normal to high volumes and automatically limit bass to prevent distortion when the volume gets really high.
    Equal Loudness Contour
    I want a speaker that sounds its best at ANY volume. I want to have full sounding bass and flat treble at low/normal listening volumes and a reduced bass and treble at high volumes to prevent listening fatigue from the ear's increased sensitivity to treble at higher volumes. The solution? A dynamic EQ (sort of similar to Audyssey's Dynamic EQ) that automatically adjusts the bass, low midrange and upper treble levels depending on how loud the speaker is playing. Notice the midrange and lower treble is kept flat. This means the bass and treble is gradually reduced as the volume increases. Low volume listening is very full and enjoyable while high volume listening is stunning and fatigue free. One dangerous aspect though is that the speaker is so smooth this way that you can play much much louder without even realizing it, causing hearing damage, potential speaker damage, and pissed off neighbors. Screw that, I like my music loud and clean!
    Superb dynamic performance
    Small speakers have restricted dynamics and can't play loud right? Not this one. The high efficiency of the system (93dB on the woofer, 90dB on the midrange and tweeter) and active crossover with powerful amps allow this speaker to play incredibly loud and dynamic. A pair should be able to produce peak SPL of just under 115dB 1 meter away. Unbelievable? Well, this speaker is really a 3 way, 4 driver floorstanding speaker packed into a small speaker. All that extra air space in a floorstanding speaker just increases the <150Hz efficiency of the speaker. I can achieve nearly the same bass performance in a small speaker, I just need way more power.
    By using 3 way, there is much less intermodulation distortion than a 2 way simply because the woofer isn't asked to do large excursions and play midrange at the same time. By using passive radiators, the woofer's excursion is greatly reduced for bass. This improves efficiency as speakers lose Bl under greater excursion levels as well as face a stiffer suspension with higher excursion levels. Both leads to reduced sensitivity at high volumes and a loss in dynamics.
    Virtually no cabinet vibration or resonance
    Cabinet resonance is an interesting issue. Unlike what intuition would tell you, a thicker wall causes bigger resonance issues! More accurately, a thicker wall causes the resonance frequency to shift higher up in frequency, and for normal thicknesses (3/4", 1"), this falls in the crucial midrange frequencies. Bracing simply pushes the resonance frequency higher.
    So, the solution, is actually to use a thinner wall. In fact, for a 1/4'' wall, the resonant frequency is around 100Hz, according to BBC's research. This is completely out of the midrange band, so the midrange enclosure suffers almost no audible resonance issues within its band. For the woofer enclosure, the midrange enclosure acts as bracing, pushing the resonant frequency up above the woofer's band. Therefore, we have a box that has no resonance issues.
    Even though the wall is only 1/4'' thick, the dual opposed woofer configuration cancels out almost all of the mechanical cabinet vibrations. Same for the 2 passive radiators. This way all their mechanical forces cancel out, leaving a vibration free cabinet.
    The woofer enclosure is also too small to have standing wave problems, so only a small amount of Acousta-Stuf material is used, and they wouldn't be effective for <400Hz anyways. It is mainly to absorb the harmonics. A layer of Fatmax dampener is lined around the cabinet. Fatmat is lined around the woofer enclosure to provide extra damping to reduce sound from leaving the box. The midrange chamber is actually made of a molded ABS plastic that is even stiffer than plywood while being thinner to save 7% of the enclosure volume. It is stuffed with Acousta-Stuf to absorb as much of the rear wave as possible.
    Minimal baffle diffraction
    With the combination of asymmetrical driver spacing to nearby edges for all drivers, as well as wool felt treatment on the front baffle, this speaker should have very minimal amounts of diffraction induced frequency response ripples. The speaker grill is also treated with wool felt on all edges and hard surfaces, so this speaker can have a grill on without affecting sound quality.
    Linear phase and time alignment
    The use of such low crossover frequencies necessitates a steep crossover, but there is a price paid for the nasty phase shift that comes with steep filters. By using FIR filters in the DSP, I can have a linear phase 4th order (or 8th order if I want) crossover. Additional processing can be done to reduce the pre-ringing caused by the steep linear phase filters. Time alignment is trivial to do on a DSP. The result is a time (mostly) and phase coherent multi-way speaker.
    And there it is! I spent way too much time and money on this. But with everything this is a speaker that should outperform most traditional "Hi-Fi" style speakers. I should check myself into an addiction centre after this :eek:.
    Continued on the next post.
    Finally, let's get to the details of the speaker components.
    Driver selection:
    This is the finest small format tweeter available with exceptional distortion performance. While very expensive, at $250 (from Solen) it is actually very cheap for a Beryllium tweeter and it performs just as well as the large (and much more expensive) Scanspeak Beryllium tweeters. It has good sensitivity, dispersion, and exceptionally low distortion down to 1000Hz. Best of all, all that performance is in a tiny 2.44'' face plate tweeter that can be further cut down to ~2'' to reduce size even further.
    This is the best sounding ~3.5'' cone midrange available, and the largest midrange I can accommodate to achieve a 1/4'' wavelength crossover frequency with the tweeter. While there are 3'' domes, they are all bigger than the 10F, and it must be crossed much higher at around 600-1000Hz when I want the midrange to be crossed low closer to 300Hz to take advantage of the clarity of the midrange as much as possible. A woofer capable of the same clarity as the Scanspeak 10F would be extremely costly and may not be suitable for bass duties. Even if I did use a driver of that quality, the woofer compartment won't be fully stuffed like the midrange chamber to absorb the rear wave, which will result in an inferior sound.
    Woofer: 2x Wavecor WF152BD05 6'' Glass-fibre woofer
    A *TON* of work was put into this task. The woofer search gave me a lot of trouble due to the sheer number of choices and trying to find one suitable for bass. This is a classic compromise problem of bass and midrange clarity. Not only many of the high quality and high fidelity 5-6'' midwoofers do not reproduce bass very well at high excursion levels, most are not designed for small enclosures and have "high" Vas and low Fs, both are not "ideal" for small PR enclosures, which leads to very poor PR efficiency and less overall bass output of up to 3dB for the same input power. A driver that is ideal for high output bass reproduction, such as the Tang Band W5-1138SMF, does not have high fidelity midrange, which would be unacceptable given the best in class sound quality of the other components.
    I almost gave up and just used a high fidelity woofer and sacrifice bass output, but after some serious digging, I found a little known driver from Wavecor that has almost the best of both worlds. It had pretty much the ideal T/S parameters suitable for my design, while having extremely good sound quality comparable to Scanspeak Revelators. The result is a woofer that is 2-3dB more power efficient in the 40-55Hz range than nearly all high fidelity midwoofers, and just 1dB less than the W5-1138SMF, the ideal miniature subwoofer driver for this application, and avoiding the 7dB less midbass because of the dreadful sensitivity. A high efficiency pro driver has great midbass output, but not nearly enough excursion for low bass. The Wavecor does it all, high sensitivity, high compliance that results in about as much low bass and mid bass output as possible from a 5L speaker.
    The passive radiators are special. This is a special oval passive radiator from Tang Band with ribbed surrounds to reduce rocking modes. It is the only passive radiator that has enough excursion and linearity to only use two PR to keep up with the 2 woofers, tune them to a very low 42Hz, and still fit in the enclosure. It should have much more linear excursion than the 5.25'' Peerless PR, as Tang Band recommends just 1 of these PR's to go with the W5-1138SMF, a woofer with higher excursion than the Wavecor. It is a shame Tang Band absolutely refuses to sell these PR's separately. So the only way to get them is to buy a bundle with either the W5-1138SMF or the W6-1139SIF, from Europe! This was not an easy (or cheap) PR to get to say the least.
    DSP: external miniDSP 2x4 HD
    This is the heart of the system that does the crossover, driver response manipulations, phase correction, time alignment, bass boost, high pass, limiting, and more.
    Amplifier: 1x ICEpower 50ASX2 SE, 2x ICEpower 50ASX2 BTL
    I will be internally amplifying using the ICEpower 50ASX2 SE (for stereo) for the midrange and tweeter, which will provide 50W @ 4 ohms for each driver. The two woofers will be powered by the bridged version of the 50ASX2, one woofer each, which will deliver up to 170W @ 4 ohms to each woofer. The woofers need a LOT of power to overcome the tiny airspace. Even though they only need about half the power, but its important to have spare headroom so the amp isn't straining. The ICEpower amps are very high performance class D amplifiers that should sound much better than most of the class D amplifiers on eBay and Alibaba that may have questionable designs and parts quality. There will be no doubts on the excellent sound quality, power output, and build quality of ICEpower amps. They have integrated power supplies, the dimensions are incredibly small and they're not horribly expensive like the Hypex NCores.
    It's going to be another few months before this gets built and gets tuned properly. Love to hear your comments in the meantime. I hope this has been interesting as it has been for me.
      Wow, I have little to say at this point other than it looks like an impressive project.
      Will you have a way to making changes to the DSP, etc., externally? I think it would be fun to be able to tinker with those aspects of the design w/o having to break the box open to attach cables, etc.
        The only critique I would have for this is that even though the amps are very efficient, having a closed box may not be the best option for cooling.
        If you can modify the design somewhat to allow for an external heatsink to allow for a path for the heat to get out of the enclosure, that might be a nice option.
        Love the choice of woofers. Those are some fantastic performers.
          Wow, very ambitious and impressive project! I will be excited to see this come together. Of those drivers I only have experience with the 10F, and will say it is a fine choice.
            Impressive project. You must bring them to DIY Iowa.
            Ron
            C-Note Iron Driver Build
            The Lydias
            The Cherry π's
            The Champs - Iron Driver 2015 Entry
            My Projects Page
            The good thing about science is that it's true whether or not you believe in it. - Neil deGrasse Tyson
            http://www.youtube.com/watch?v=cjuGCJJUGsg
              This does look amazing! Can you give a estimate of what the total build cost will be for a pair?
              Edit: I just looked up the cost of the tweeters alone, there goes my hope for building these beasts...
                Wow, nice... would be fun to see this at Indi, hope you complete in time. Mine got derailed pretty recently, due to driver issues.... but there still time. looking forward to this build thread
                  Since this is an active solution, you have options. You can build a similar speaker with different drivers if you understand the principals and DSP programming.
                  My "No-Name" CC Speaker
                  Kerry's "Silverbacks"
                  Ben's Synchaeta's for Mom
                  The Archers
                  The Gandalf's
                    yes, many a good $50 tweeter can be substituted for it, and tweaked in the DSP, though you would need measurement equipment. Those tweeters are really nice, but this is an ultimate build. Wavecor drivers are also difficult to source in the US (which is why even they are more reasonable in cost and offer fantastic performance, there are not many builds with them). if any the PRs would be the biggest hurdle. There simply isn't a great choice in PR. and PR is a must for small box low tune, as the ports gets ridiculously long in these applications... though clever solutions like Bills resonance traps exists. Also icepower amps are not readily available... though they come up for sale now and then
                      Where did you get the idea for that tweeter?
                      Any preference on the FIR software?
                        Thank you everyone for the compliments!
                        Yes, the DSP is external for this very reason. Eventually I want to put the DSP inside for a really clean all-in-one package, but it'll likely be 1-2 years before I can get to that point.
                        You're right, and unfortunately heat is an issue that I don't have a good solution for. The speaker is too darn small and it really limits what I can do.
                        It costs about $3000 for a pair. ​I don't really recommend anyone trying to build this. It is exceedingly difficult and expensive to build and some parts are really hard to get. Part of the joy is the struggle to really push the limits and not settle for anything other than the best. For the money I also had an absolute blast during the whole year long process of designing this speaker, way way WAY more than say, a vacation would bring, and that's an incredible amount of enjoyment that others won't get when duplicating the speaker.
                        Even if you modify it, significant changes would need to be made that would greatly change the size and performance of the speaker.
                        ​I hope they'll be done by then. I should be able to attend InDIYana since it is just a 7 hour drive away.
                        Ron
                        ​I'll try to attend DIY Iowa, however the flight is quite expensive as I'll likely be in Europe during that time. However I will find a way to get you to hear this like I promised before.
                          Haha no one in particular (looks away from you)
                          I only got to try 2 since nearly all of them are paid software. I liked FIR designer, quite powerful and not hard to use. rePhase is nice too for some simpler stuff. Want to try Acourate, but it is very expensive.
                            How much room will they need around them? Will a U-shaped bracket to hold them horizontally(these are gonna be heavy like a chunky traditional amp) be possible w/sheet metal, or will it have to be small solid stock? Love the idea, tho I'm wary of Be in humid places.(we'll know in 5 or ten years if they last 5 or ten years, I'll just let others be the test mammals). Plenty of small form tweets around good enough for old ears.
                            Thanks for showing us this, looking forward to seeing it built.
                              Brian,
                              What an impressive speaker you're designing. I'm hoping to hear these at the 2017 MWAF? I'm so glad I'm staying for the open unlimited, lots of tasty treats in that category so far!
                              TomZ
