Bantams MTM Underway...
  • #61
    Originally posted by imakethings View Post
    Tom did you use the same crossover from the bantam TMs?
    No, I started from scratch for these basically. These use the 8 ohm version of the ND91...I still haven't finalized the crossover for these. Not that they sounded bad last year in Indiana, but I think I may try to revisit the crossover again to see if I can possibly simplify things a bit. I think I can get the tweeter crossover parts in the base, then just have the woofer crossover bits to attach to the rear baffle. It's been awhile since I've even listened to them, gotta get back to these soon.
    TomZ
    • #62
      No, I started from scratch for these basically. These use the 8 ohm version of the ND91...I still haven't finalized the crossover for these. Not that they sounded bad last year in Indiana, but I think I may try to revisit the crossover again to see if I can possibly simplify things a bit. I think I can get the tweeter crossover parts in the base, then just have the woofer crossover bits to attach to the rear baffle. It's been awhile since I've even listened to them, gotta get back to these soon. TomZ
      Thanks! I think these will make a good portable radio that would spend most its time in a bedroom.
      • #63
        Hello Tom,
        I had to dig out this topic since I find you mtm concept very interesting. I would like to combine this Bantams with my Aliante subwoofer. Since the last update was a few years ago, did you finish the crossover design and could you share the values?
        Best regards
        Chris
        • #64
          Originally posted by Deadeye5589 View Post
          Hello Tom,
          Best regards
          Chris
          You know, shame on me, but I never did finalize a crossover for these. There are a few reasons for this, but suffice to say that I probably won't get to it for some time.
          I think I would have been better off just going with the original Bantam's for that DIY Indiana event as I compromised this design just a bit in my opinion.
          I didn't love the effect the rear mounting had on the woofers -- there were some diffraction issues that didn't exist on the original flush mounted Bantam's speaker system. Also, I should have gone larger on the internal volume for one thing... Just tried to make it work for that particular DIY event and I probably shouldn't have.
          The guys that can do these Indiana designs and stay within the criteria while getting excellent results are doing some amazing problem solving and driver/enclosure work in my opinion.
          I could get these sounding pretty good I think, but I have other things I need to finish up first. I'm sorry about that.
          TomZ
          • #65
            Hi Tom,
            Thank you for the heads up. So you would not advise to build those mtm Bantam. Shame the design really did look sleek with the back mounted speakers. The high WAF was a reason why I would have liked to build a pair for my office desk. Maybe I go with the original Bantam instead, but I fear that they are a little bit underpowered for my 2.1 setup.
            BR Chris
            • #66
              Hi Tom,
              BR Chris
              I think I could have done more with the crossover and flattened it out a bit. Honestly, I didn't think they sounded bad, but I would have liked to do a little bit more tinkering with the crossover. They were in a tupperware container hanging from the back of the speaker -- not finalized and installed. I've never done that before, but I just wasn't 100% sure that I liked the result enough to call it 'done.'
              TomZ
              • #67
                Curious if you had any probs offsetting the AMT tweeter? I think it's a great design btw.
                • #68
                  Thank you sir.
                  These were designed for a particular size constraint, so I had to squeeze the drivers in the only way they would fit, and this was really the only way possible with the base that I wanted to use. If I put them in straight vertically, the drivers wouldn't have fit.
                  To answer your question... yes, it was really tight in there. Had I not been using strong hardwood for the front baffle, I'm pretty sure I would have broken those little pieces of wood between the woofer openings and the tweeter hole just in handling and machining/sanding it. This box was just way to overengineered and complicated. I can tend to do that, but this time I think I just went too far.
                  Again, I have lots of respect for the guys who do the DIY Indiana builds and can follow the constraints and still make something amazing... that's outs my league!
                  TomZ
