Midwest Audio Fest
See more
See less
PE Subwoofer Pre-Amp - Exposed
  • PE Subwoofer Pre-Amp - Exposed
    Note: To view pictures in full size, right click the picture and select "open in new window".
    Introduction:
    Then he shipped his last unit to me for analysis, thanks Gordy.
    Summary:Overview:
    The subwoofer pre-amp performs three functions: (1) It sums a L-R stereo signal to provide a combined subwoofer output signal; (2) It provides an adjustable gain for the subwoofer output; and (3) It supports an adjustable LP frequency.
    One of two potentiometers controls gain that can be varied between zero gain (i.e., no signal out) and ~10.5x gain. This potentiometer works as expected. An audio frequency, 1st order bandpass filter is integrated into this circuit. The HP F3 is fixed at 3 Hz. The LP F3 decreases with increasing gain but never gets below ~10 KHz @ maximum gain. So it doesn't affect the subwoofer out signal.
    The second potentiometer controls the sub's LP F3 frequency and this is where some problems exist.
    Analysis:
    Original Module: 9 Hz to 107 Hz Adjustment Range
    The sub's LP filter is a 2nd order Sallen-Key topology as are most active, analog 2nd order filters. The original filter's Q factor is 0.73; very close to .707, aka Butterworth dampening. After modifications, the Q factor is virtually unchanged at 0.74.
    Initial Testing:Graph 2.jpgIn a single supply op-amp circuit, signal bias resistors are needed to shift the 0 value of an ac coupled signal to half the supply voltage. This allows the op amp to reproduce the positive and negative portions of the signal (i.e., instead of V- to V+, the signal has a DC offset and spans 0V to 2V.
    Solution:
    First, the capacitors in the Sallen-Key filter were reduced to allow a higher F3 frequency. The 0.22 uf capacitor, C5 (EDIT: not C6), was replaced with a 0.1 uf capacitor. The 0.47 uf capacitor, C6 (EDIT: not C5), was replaced with a .22 uf capacitor (i.e., EDIT move C5 to C6 position and insert a 0.1 uf cap into C5 postion)
    Final Testing:
    Post modification, the measured results coincide with the expected performance of the modified module.
    The 20K "A Taper potentiometer can be procured from Digi-Key (TT Electronics # P092NQC15AR20K).The part cost ~$2.40 and the shipping cost was reasonable at ~ $3.50. Most any film / polyester capacitor can be used for the 0.1 uf replacement.
    Side Note:
    The measurement graphs show the effect of the 1st order HP at the input stage (F3 = 3 hz). If a higher HP point is needed to limit sub Xmax, replacing the two input signal decoupling capacitors can achieve a higher HP F3 (aka PLXXO). With the existing 4.7uf capacitors, the 1st order HP F3 is 3 Hz. Replacing those two capacitors with lower values yields the following: (1) 1.0 uf, F3 = 16 Hz; (2) 0.68 uf, F3 23 Hz; (3) 0.47 uf, F3 = 34 Hz and (4) 0.22 uf, F3 = 48 Hz. The effect of the HP stage on subwoofer performance can readily be modeled in WinISD.
    Last edited by Millstonemike; 03-21-2017, 06:25 PM. Reason: The wording in the "Solution" paragraph had C6 and C5 reversed. This has been corrected in the paragraph in bold. The original red markups on the schematic are correct and have not changed
    Awesome Mike! Well done!
    Dan
    _____________________________
    Tall Boys
    NRNP Computer Sub
    The Boxers
    The Hurricanes
    The Baronettes
    Conneccentric
    UX3
      Very nice!
      Wogg Music
      Published projects: PPA100 Bass Guitar Amp, ISO El-Cheapo Sub, Indy 8 2.1 powered sub, MicroSat
        The mods you made would have added to the piece cost minimally if implemented by the manufacturer, and they didn't just make the device better - they were the difference in being useful in the intended application or not. So I have to ask the question... why would a manufacturer make a device that doesn't work when they could have so easily made one that does?
        Dan
        Tall Boys
        NRNP Computer Sub
        The Boxers
        The Hurricanes
        The Baronettes
        Conneccentric
        UX3
          This is an awesome set of mods sir. Thank you for taking the time to do this. I plan on giving this a try soon.
          There are some majorly smart dudes on this board!
          TomZ
            Dan
            ​Possibly engineered by someone that wouldn't use it as intended. The solution doesn't change cost to manufacturer at all, like for like part swaps +- pennies. Perhaps this will lead to a revision. Perhaps someone at PE could pass this along to the supplier?
            Wogg Music
              Okay- A and B are what taper? A = audio/log? B = linear? or vice versa?
              Oh- the 100uF (C8) polarized cap that is then removed from the circuit by way of removal of R7- Can you just then parallel it then with the 220uF (C3) cap to add to the PSU regulation?
              Thanks, Mike- you really did good here!
                C3 is regulation on Vcc. C8 is regulation on the 1/2 Vcc still connected to the 1/2 Vcc point between R4 & R5 even after R7 is removed.
                A and B are both audio tapers. Unfortunately, even the quality pot mfg.'s (e.g., Bourns) didn't specify the version of the A taper.
                  So basically, you're removing the .22 cap and reusing it elsewhere in the circuit.
                  The only new components are the .1 cap and the pot?
                  Would you be able to provide a part number suggestion from Digi-Key for the .1 uf cap to get this all in one order?
                  Again, thanks so much for the help making this thing a hugely better product. I have plans for two projects that will use this upcoming.
                  TomZ
                    Maybe DA should hire you as an R&D consultant? It certainly SEEMs so!
                      The only new components are the .1 cap and the pot? Correct
                      Would you be able to provide a part number suggestion from Digi-Key for the .1 uf cap to get this all in one order? Digi-Key doesn't seem to offer a 0.1 uf in a narrow size. Try a KEMET RSBDC3100AA00J, its a box cap w/ correct lead spacing but it's a little larger than the one I used from my parts bin. It should fit. If it doesn't, let me know and I'll mail you some.
                      I'm sending the modified unit back to Gordy next week. Maybe you should wait until he tests it out. I've only had this up on the scope, not a live test.
                      TomZ
                      1
                        A wise old colleague once said; "Never make the mistake of mixing your avocation with your vocation." Besides, I'd rather help you gents out when I can. Many here certainly helped me.
                          What a great write up! Thanks Mike! My father stills tells me to this day, don't make you hobby your job. Wise indeed.
                          The Madeleine
                          The Roxster
                          Swopes 5.0
                          Acoustic Panels
                          Living Room Make Over
                            [ATTACH=CONFIG]n1320160[/ATTACH]
                            I don't see anything else connected to the other end of C8 in your schematic, or is it not all shown? That would leave it out of the circuit. That's why I asked.
                              ​It's missing the node dot in the schematic, should be on the same connection where R4 and R5 meet.
                              Wogg Music
