U-Baffle conciderations
  • U-Baffle conciderations
    Hi,
    I am doing a homage build that will require a u-baffle/tunnel behind the mid-range. I am fairly sure it needs to be treated like a OB with a REALLY thick baffle, but my knowledge ends there. I understand the concepts of OB/ U-baffle, but this will be my first ground-up design of one. ,
    Let's say the Woofer will be of a 10-12" variety, the mid 3-4" variety, and tweeter a 3/4" dome. Without stating specific of woofer/mid/tweet combo, what are the general considerations those who have has OB success (sans DSP) of such a design?
    My attempt with this thread is to start broad and narrow the design down as discussion marches on. Yes - U-baffles are less than ideal, but it is a requirement of the design so changing it is not an option. The Statement series sounds pretty darn good, so I know it can be done! Thanks!
    U-baffles do suffer from standing waves so just be ready.
      Good luck! A lot theory, but little practical examples.
      Kenny
      http://www.diy-ny.com/
        Thanks Pete, I am actually going to use a 4" diameter cardboard tube that is a little thicker than 3/8". It is inherently more dampened than PVC, or a wood tunnel. I am also going to stuff it a bit.
        I am hoping that will help...
          John K's excellent web site--Music and Design--has studies of open baffle speakers with theory and simulation/measurement results. Just read a bit and you will be learn about u-baffles and more.
          www.musicanddesign.com/
            You know Jim,
            This should have been an obvious place for me to look. I have met John a couplenof times at DIY NE and he is a real gift to us. His work on crossovers and polar patterns is a priceless, real-world study.
            Thanks a bunch!
              This might help (maybe not) http://www.quarter-wave.com/OBs/U_and_H_Frames.pdf
              Sausage With Meat Sause, Please
                Horn Response can model this. Typically you would want to avoid the cavity resonance as it's difficult to remove.
                John H
                  I think I am going to have to dampen the cavity resonance. It is right in the pass-band of the mid(1750 ish. A saving grace is going to be step compensation will be pretty much on the midrange if I choose to cross high, but not out of the 4pi raidiation of the woofer. This will be around 800Hz or so with a 16" wide front baffle.
