Is this a reputable design?
  • #16
    It could simply be the challenge to use this combination of speakers and get the maximum of each.
    Kenny
    http://www.diy-ny.com/
    • #17
      I've always though that the term FAST is really an odd acronym. There are just some methods that don't need a goofy name. I would say this speaker would better be labeled as a 1.5 way myself. I'd say it looks like an ok build if you don't mind the sound of a full range driver. I don't like the massive rise in the top end. It's only a 4 ft tall speaker and the full range drivers center is about 35.5" which should be pretty much on axis and ear level when sitting on a couch. That will make that rising top end even worse. If it were me I would try to tame that driver's top end some.
      If I wanted serious volume I would probably go with a bigger full range driver that can take the power. He says it is crossed near 400hz, so a bigger full range driver in the same enclosure volume likely won't be a problem. Even better might be to use a coaxial and convert it to a 2.5/3 way. If one were going to go through the trouble of taming the rising response or changing the filter for a bigger driver.... it wouldn't be much more work to change it to a 2.5 way. It is a neat looking design, but I think it could be improved quite a bit and keep the theme imho.
      I like full range drivers, but mainly when augmented with an extra bass speaker and a super tweeter, essentially making a 3-way with the full range covering the majority of the spectrum.
      • #18
        Originally posted by make_some_noise View Post
        I've always though that the term FAST is really an odd acronym. There are just some methods that don't need a goofy name...
        haha
        I had not heard that term before today and thought the same thing.
        I didn't see that that on the Emil Attlid webpage.
        If so the 600mm separation between drivers is excessive *
        ( not very attractive either - but that's just aesthetic opinion )
        * This could explain the statement
        Vertically is a bit troubled due to the distance between the drivers
        • #19
          Lord. I'm never gonna get started lol. Sent from my iPhone using Tapatalk
          • #20
            Well, when you start please post your progress.
            Kenny
            • #21
              Well I want to I just don't want to build something that's like one of those stories like on undefinition of first time builds http://www.parts-express.com/peerles...ofer--264-1098 http://www.parts-express.com/peerles...-ohm--264-1381 What about this woofer and this tweeter in a 2.5 way with my w4 TB? Now I'm back to breaking the rules about first builds again. Sent from my iPhone using Tapatalk
              • #22
                That would be more of a 3way.
                • #23
                  The tweeter will want to be crossed at 3.5K Hz or above. You will have a hard time crossing the woofer much above 1K Hz. That leaves a pretty big gap.
                  • #24
                    You know maybe I'll still just use this as a learning experience and build it. If someone would like to help me correct the the xo design for a w4 version of that driver great. If not I'll build it as is. If it doesn't live long term in my living room it will get paired with a Sansui which I think is rated at 22 or 25 watts. Is that even worth adding the w4s? I do like to play things loud at times. Sent from my iPhone using Tapatalk
                    • #25
                      ... it will get paired with a Sansui which I think is rated at 22 or 25 watts....
                      Note this bit from the link you provided:
                      The low end is a bit hard to drive with a min. impedance of 3 Ohms. I recommend a beefy amplifier for these, preferably above 150 watts per channel and a good power supply.
                      His Impedance/Phase Graph would support this.
                      • #26
                        Originally posted by Sydney
                        Note this bit from the link you provided: His Impedance/Phase Graph would support this.
                        Well then I'm clearly out of my element. I'll build them and experiment. Figure out how full of **** I am. Sent from my iPhone using Tapatalk
                        • #27
                          Looks like a great speaker for single men.
                          Shawn
                          • #28
                            Shawn
                            Nah, the enclosures I just built are 48x11.25x12.75" and I am married. I also have a 4.5 cu ft and 12 cu ft subwoofer too. I have to admit I have a pretty cool wife though
                            • #29
                              25 watts? Look at these. I built them for a 17 wpc tube amp, very happy.
                              http://speakerdesignworks.com/Singularity_1.html
                              • #30
                                I also have a 6 channel ph6 capable of bridging to like 300 watts x3 so. Sent from my iPhone using Tapatalk
