Rs-p wmtmw cc
  • #76
    baffles cut ... i found a piece of plexi that was the same thickness of the plastic base that came with my router , this makes a great jig . being clear and able to see through makes it easier to work wit . you see what you're cutting and setting the pin was so much easier ....
    Paper Towers
    RS180P/28F surrounds
    Boombox
    • #77
      I would suggest dividing the woofer chamber in half so that each woofer can be measured independently.
      • #78
        to late .... but it's fine .
        Paper Towers
        Boombox
        • #79
          prototype in position . i like it , it brought the bass shelf up a bit and thats not a bad thing . the 180P's can use a lil help ...
          hongrn , how is the proportion ? i think i nailed it . the mtm box is the same size as the TV base ....
          Paper Towers
          Boombox
          • #80
            opps double post .
            Paper Towers
            Boombox
            • #81
              still liking the prototype in place so i think i'm going to order at least a pair of 125P's so i can get my towers back together and have a good listen with my full sound stage . i also need to get some wire so i can pre-wire the new box as the baffle will be permanently attached .
              i did plug in one of the towers last night for some stereo voicing , it kept up very well and sounded great !
              Paper Towers
              Boombox
              • #82
                been super busy at work this week and tired when i get home, good thing is my leg is feeling much better with the new medication i'm on . this sits in the middle of my room as a reminder . looks lonely doesn't it ?
                hoping to have it together this weekend . need to caulk all the seems , pre-wire , line and stuff and attach the baffle . also need to test the RS28F with a damaged screen , gonna remove the screen altogether as the last time i tested it showed a lot of distortion which i believe is coming from the screen in my attempt to fix it ....
                Paper Towers
                Boombox
                • #83
                  i got nothing done last weekend , had to play mechanic for a friend . i did watch a bunch of movies over the weekend and am very happy with how dialog sounds ! i'm getting what i need outta the prototype so i've begun to think about a finish . talked my buddy that owns a body shop and he said as long as i pick a color he has in stock already and i do the sanding he would charge me nothing to spray it . i'm thinking a dark charcoal metallic will look really good with the paper cones ...
                  Paper Towers
                  Boombox
                  • #84
                    well guys , i go to the vascular surgeon today . i got no lie i am a bit nervous ! hoping to at least pin-point the fix for my leg ....
                    Paper Towers
                    Boombox
                    • #85
                      Good luck! Hope you get it figured out.
                      -Kerry
                      • #86
                        thanks Kerry ... there is a small lump in my left calf that i believe is causing all the issues and needs to come out . however , my primary DR. believes the the circulation issues are whats causing the lump ...
                        Paper Towers
                        Boombox
                        • #87
                          not what i really wanted to hear ! surgeon thinks it clots in my arteries in my left leg . CAT scan scheduled and most likely a stint ...
                          Paper Towers
                          Boombox
                          • #88
                            damn guys , looks like all my projects just got put on hold ! CTA scan reveled that the artery in my left leg is almost completely blocked with plaque and clots from my pelvis to mid thigh . i will need a femoral artery bypass and will be out of commission for at least 6 weeks .
                            Paper Towers
                            Boombox
                            • #89
                              Sorry to hear about the health issues. I'm approaching that age where many friends and family have gone on, so believe me when I say, best wished for a complete and speedy recovery.
                              • #90
                                thanks .... thats the thing and why it took longer than it should have to diagnose , i'm only 49 .
                                Paper Towers
                                Boombox
