Dayton Audio or Kicker?
  • Dayton Audio or Kicker?
    Hey there, can someone tell me which subwoofer would be the best to a home audio setup (might be used on car too) and to pair with the Yung 200W plate amp?
    Kicker: https://www.parts-express.com/kicker...-ohm--267-6909
    Dayton: http://www.parts-express.com/dayton-...oofer--295-488
    Yung amp: http://www.parts-express.com/yung-sd...35-hz--301-506
    Thanks
    Vasco
    The kicker looks like a kids running shoe and is best used in a sealed cab - is that what you are looking for?
      I was thinking on a vented box, with the rectangular hole at the bottom. Thanks for the reply
        Spend a little more on the Dayton Reference Series subwoofers, you won't regret it.
          I've heard and seen the reference ones but I'm on a budget and I've passed it a bit alredy. I can only go for the Kicker or the Dayton SD315. What's your suggestion? Thanks
            My suggestion is to wait until your next paycheque and get the Reference series, but since you've narrowed it down to those to - use the Dayton SD315.
              I don't really have paychecks, I'm just a teen whose birthday is next month and I thought I would make a subwoofer :p. Thanks for helping though, really appreciate it!
              PS: I wouldn't mind having the reference ones ;).
                I think four GRS 12" drivers and that Yung amp would suit your needs :-). Leave it sealed.
                  I want to make a single driver box. I want it to be somewhat "portable" between home and cars. Thanks for the suggestions though!
                    What did you mean by "Leave it sealed"? A sealed box? Thanks
                      How are you planning on powering that plate amplifier in a car? Your house and hour car have very different power sources.
                      ​Check out this ISO El-Cheapo, it's very high on the bass per $ scale. I have a teenager with that in his car and is quite happy with it, and back long ago with a different set of similar woofer that little cabinet did a decent job in my living room.
                      Wogg Music
                        ​Check out this http://techtalk.parts-express.com/forum/tech-talk-forum/1319471-iso-el-cheapo"]ISO El-Cheapo[/URL], it's very high on the bass per $ scale. I have a teenager with that in his car and is quite happy with it, and back long ago with a different set of similar woofer that little cabinet did a decent job in my living room.
                        12V to 110VAC or 220VAC 500W inverters. After the math it consumes 40A, not much for a car.
                        For the subwoofer, I'm on a budget but since it's a single driver I want it to be something good (not saying GRS is bad, but I preffer Dayton).
                        I would use GRS if I used 2 subs but I only want 1 sub.
                        Thanks for the suggestion though!
                          That GRS will embarass that Dayton for a lot less money, but hey, check my signature.
                            Nice signature hehe. So do you guys think I should get the 12" GRS Sub instead of the Dayton? Have you experienced the GRS live? Why is the dayton more expensive then? (If the GRS beats him). Thanks
                              And can I push more then 120W RMS on the GRS? Since the Amplifier is 200W RMS...
                              Per example if I push 150W RMS or more, will it distort? And would the Dayton distort? Thanks
