Check out the new high sensitivity driver from Dayton!
  • Check out the new high sensitivity driver from Dayton!
    Hey guys,
    We just launched a new high sensitivity mid-bass driver you might want to check out. It's great for just about every application, car, high efficiency home audio or even pro sound. This would make a great option for getting insane output from even the smallest of portable boomboxes as well. AND...its good to ~2.5k up to 75 DEGREES off axis!
    I just installed a pair in my car and the difference in output is astounding using the factory head unit. Just in case you haven't seen them yet, take a look. We also shot a quick video of my install.
    http://www.parts-express.com/dayton-...4-ohm--295-348
    https://www.youtube.com/watch?v=Xt6L3ymsulI
    Advertisement plug /end.
    Matt
    Your results may vary.
    Very cool! Should really own its niche. One question, the pdf says the magnet is neo, but it looks kinda too big to be neo? Or maybe not.
    ~Brandon
    Soma Sonus
    DriverVault
      Saw this the other day. Still waiting for a ~4" PS series driver.
      The Madeleine
      The Roxster
      Swopes 5.0
      Acoustic Panels
      Living Room Make Over
        Interesting, that is one big neo slug on that sucker! I have just a bit of commentary:
        -Qts is low, obviously due to the high motor strength, but I find it odd since that is usually not a goal for a "purpose built car audio" driver. Usually you see high Qts here for sealed / open baffle type of installations (reference the youtube video for example).
        -The sensitivity listed solely based on T/S is a bit misleading IMO, and inconsistent with the rest of Dayton's products. Just look at the PS180 for comparison, a proper 95dB driver, and this one should be listed at 95dB as well since that is the usable sensitivity.
        -Sixty Five??? Who chose the part number? Literally every other Dayton product number is listed in millimeters, such as PS180, PM180, RS180, etc.
          Look again at the magnet. Instead of dark ceramic, it looks to be a slug of shiny neodymium! Yeah, we're not used to seeing neo magnets that big.
          I wish PE had these when I was looking to re-do my front speakers in my car awhile back!
          TomZ
            What's the diameter of that phase plug? It seems larger than normal but the VC is only 1 inch. Like others, I'm looking for a good coax candidate.
            John H
              I think the 65 in the model number follows convention with car speakers. Many have some type of reference to the size in inches in the model number. As in 65 for a 6.5 inch speaker.
              TomZ
                Saw these drivers at the PE booth at Axpona. The come profile where it meets the cone is quite different than usual and transition from the smooth cone to a sharp drop towards the voice coil creating a small valley between the phase plugs and the flat portion of the coil. Unfortunately it wasn't playing, so don't know how it sounds.
                Pretty handsome looking driver
                  We need a 2 ohm version for GM and Chrysler products!
                    Might be a good option there...
                      A ~250hz f3 seems awfully high for car use. That said, if the distortion is on par with Dayton's other high efficiency drivers, I'd put it in a tower and call it a day...
                        They make the phase plug sharp enough!
                          Nice to see you back, Spaz!
                            I LIVE!
                            I spent a few years as an extra in a Hunter S. Thompson movie, but I got better.
Name:	IMG_2148 (Medium).JPG
ID:	1331183 Click image for larger version
Name:	IMG_2147 (Medium).JPG
ID:	1331184 Click image for larger version
Name:	IMG_2149 (Medium).JPG
ID:	1331185 Click image for larger version
Name:	IMG_2150 (Medium).JPG
                              It is neo, and a powerful sucker at that.
                              Copper cap peaking out in that last picture.
