Pioneer HPM40
  • #31
    i think this looks pretty good . moved the tweet cross just past 4k .... Chris , you see what i mean about the mid not showing up ?
    Paper Towers
    RS180P/28F surrounds
    Boombox
    • #32
      it dawned on me this morning that i have another cab that these drivers , the tweet is the only different one , would bolt rite into . " Frankenspeaker " .... i may give this a try also . i put all parts including the simmed XO in a PE shopping cart and was pleasantly surprised at $345 ....
      Paper Towers
      Boombox
      • #33
        tweets are in hand . unfortunately the are quite a bit smaller than the BG25 so there will be no Frankenspeaker resurrection ...
        now never working with a ribbon before , i know to use a 20-30uF cap for testing . is there anything else i need to know ?
        also in the Pioneer cabs i'm going to have to mount the MT vertically , is this going to cause issues ?
        **Edit : i meant horizontally on the MT
        Paper Towers
        Boombox
        • #34
          had a good chat with Josh last night and come up with a plan . because of all the diffraction issues with square edge and 1/2" sq. stock grills . i'm gonna surface mount everything and cover the baffle with felt or speaker carpet . surface mounting will allow me to still cut in a big guide when i get ready . i still want to do the 2 way with a dome in a big guide
          Paper Towers
          Boombox
          • #35
            the little plastic bowls on the right are what i'm gonna try and seal the mid with using construction adhesive ....
            Paper Towers
            Boombox
            • #36
              plastic bowl seems a good fit ...
              Paper Towers
              Boombox
              • #37
                Originally posted by filmslayer View Post
                ... because of all the diffraction issues with square edge and 1/2" sq. stock grills . i'm gonna surface mount everything and cover the baffle with felt or speaker carpet . surface mounting will allow me to still cut in a big guide when i get ready.
                I have the same issue with "restoring" my original Large Advents with the utility cab.'s. The baffle is recessed 1 1/8" and the front edges are square. But the fried egg tweeter is so ugly - orange fried egg, in a black diamond back plate, offset from a silver rectangular mounting plate, and a concave metal grill that looks it it did duty BBQ'ing hot dogs at a company picnic - a front grill is a must.
                I plan of using MDF for the grill. It will be flush with the cabinet front edges, meet the drivers depth-wise with outward round overs and foam encircling the drivers. There's not much I can do about the square edges.
                I think Advent saw issues as the tweeter grill cutouts were rectangular to start and then they switched to a circle. And, IIRC, someone here mentioned the Advents measure much better with the grill on rather than with it off.
                • #38
                  i'm gonna take at look at both , grill /no grill . none of my speakers are covered , but these 40 year old grills are still in perfect shape so why not ....
                  i'm also playing with the idea of laying this on it side so my M/T will be in the vertical and measuring on the floor firing up for a large desktop monitor .
                  Paper Towers
                  Boombox
                  • #39
                    ready to measure ....
                    Paper Towers
                    Boombox
                    • #40
                      have to admit i'm nervous about testing the NeoCD1.0 .....
                      Paper Towers
                      Boombox
                      • #41
                        all measurements from same spot, 3 foot on design axis with same amplitude .
                        NeoCD1.0
                        TF0510
                        PA255
                        Paper Towers
                        Boombox
                        • #42
                          ordered a couple of small caps and coils i did not have last night . here is the prototype XO i'm gonna start with ...
                          Paper Towers
                          Boombox
                          • #43
                            we got parts ! slight miscalculation on timing . will not have it together before kickoff ... roll tide !
                            Paper Towers
                            Boombox
                            • #44
                              looks like i need a lil work on the mid . i have a 1.8n resister in series , i think i'm gonna take that out . despite what these squiggly lines look like i'm not far off . the speaker sounds pretty good !
                              Paper Towers
                              Boombox
                              • #45
                                took out the 1.8 in series went down to 2n from 5.6 on the zobel and changed the 2nd cap from 10uF to 7.5 . i also added 1.8 in series to the tweet . stating to look better and this is where i'll leave it tonight ...
                                Paper Towers
                                Boombox
