BSC Question
  • BSC Question
    Quick question. In thinking about a paralleled resistor/inductor placed in series with a driver, I understand that the resistor's value determines the amount of high frequency attenuation. But (all things being equal) does an increase in the inductor's value shift the filter's midpoint frequency higher or lower?
    Thanks!
    Lower......
    Look at it as if you are effectively rolling off the "Highs" at a 6db/octave rate. A big inductor will start the rolloff lower in frequency.
      Makes sense when you explain it that way. Thanks!
        Originally posted by fernandov View Post
        ... does an increase in the inductor's value shift the filter's midpoint frequency higher or lower?...
        The inductive reactance of an inductor increases as the frequency across it increases therefore inductive reactance is proportional to frequency ( XL α ƒ )
        Simply it is a low pass action - larger value, lower frequency
        http://www.electronics-tutorials.ws/...nductance.html
          extra thought: (except for "notch" type filters: LC/LCR - anytime both an inductor AND cap are involved - I THINK) whether in series or parallel (shunt to gnd) and regardless of filter type (LP, HP, or BandPass), LARGER (uF OR mH) always involves a lower Freq., and (vice versa) smaller is higher.
            I know you already have your question answered. However, I have found this tool can be helpful as a good starting point for a BSC: http://diyaudioprojects.com/Technica...it-Calculator/
            All about Speaker Design YouTube Channel
